Hello
I have a problem with activation autodesk Autodesk 3ds Max 2012 64-bit
the problem is that:
When I clicked on "Activate" and next "Continue" the next screen was "Processing Error"
Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems. |
Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days.
I have a student license
Solved by jessica.t. Go to Solution.
Welcome to the community Fredrik!
Can you please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request code, or contact our License Assistance Team for direct support.
Hi Theo!
I just processed your activation code which should have arrived via an automated email.
For future reference, you can also obtain direct activation support from our License Assistance Team.
Please don't hesitate to let us know if anything else comes up!
Hi Michal!
Can you please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request codes, or contact our License Assistance Team for direct support.
Hi Andrey,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code.
Hi vanesy,
Please send me your serial number and request code via Private Message and I'll help you with this(click on my camilo.lemos profile name and then on Send This User a Private Message).
Best regards,
Hello my name is Théo and when I click on activate my license for 3ds max , 3ds max displays an error :
"Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems.
Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days."
Can you help me please ?
Hi Theo,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code so I can check on my mind and manually generate the Activation Code.
Hi Klara and welcome to the community!
Can you please send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message).
Thank you,
Hi, Joane!
I wrote private message with my serial number and request code but, i am stiil waiting for your response.
Have same problem. Error 400 for AutoCad 2013 for education..
Who will receive a PM from me with serial number etc.?
/Mikkel Færgemand
Aalborg University
I have this problem, with student version for MAYA 2014.
"Your online activation request has returned an error (400)"
Thanks from France for your answer.
Welcome to the community Mehleb and Mikkel!
Can you both please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial numbers, product keys, and request codes, or contact our License Assistance Team for direct support?
Hi
I have the same problem with my software but with all of the products. I tried to download different versions of 3ds Max and Alias Automotive and none of them could activate. I always see error 400. Can You help me? I have student license and using it only for learning.
Regards
Hi slash.g and welcome to the forums!
Can you send me a message (click on my patricia.cuizon profile name and then on Send This User a Private Message) with your serial numbers and the request codes for each product you are trying to activate so I can manually generate the activation codes for you?
Hello, I have the same problem with Autocad Civil 3D as Autocad 2013.
I am from Spain and is a Spanish version.
Is a student license.
If anyone could help me!!!
Thanks.
(Sorry if my english is not perfect)
