Hello
I have a problem with activation autodesk Autodesk 3ds Max 2012 64-bit
the problem is that:
When I clicked on "Activate" and next "Continue" the next screen was "Processing Error"
Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems. |
Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days.
I have a student license
Solved by jessica.t. Go to Solution.
Hi gkki,
I've just replied to your private message.
Best regards,
Hi
I have the same problem with activation the Autodesk 3Ds MAX 2014 64-bit. (error 400) I have a student license. Can you help me with activation? Thank you in advance.
Hi dahunpao,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Request Code so I can manually generate the Activation Code.
Hi dahunpao,
Could you send me the serial number and request code via Private Message and I'll get this sorted for you right away?
Thank you and apologies for the delay.
Hello Ãliott!
As this will require an activation code be generated on our end, can you please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number and request code, or contact our License Assistance Team for direct support.
Hi Ãliott,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code.
For future reference, you can also contact our Registration and ActivationRegistration and Activation team directly for any activation issues.
Hi! I'm having the same problem when I try to activate 3DMax 2013. I had the same problem a few months ago when I tried to activate other autodesk programs. Could you help me?
Thank you.
Hi alolpe,
Can you please send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)?
Thank you,
Hello, mi name is Cesar and i have the same problem with mi activation code. I click on activate , and the program show me this :
Please help me!!!
Hi Cesar,
Hi attto85 and welcome to the forums!
Please send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)
Thank you,
Hello
When I try to activate 3DS MAX 2013 64-bit (student version) I get error (400) message. Please help.
