I am working in Civil 3D 2011. All of the required updates and service packs have been installed. I also had Autodesk Vault 2011 installed prior to downloading the SAC. Once I realized the SAC installer would not work with Vault, I uninstalled that program as well. I then attempted to install the SAC, which did appear to install on my machine. However, when I attempted to open Civil 3D after the installation, it would shut down before completely opening. I tried to repair and reinstall Civil 3D with no luck. It wasn't until I uninstalled the SAC that I was able to open Civil 3D. At this point, I am operating under those circumstances, without the SAC being installed. Does anybody know how I can get the SAC on my machine and operational with Civil 3D? Or, why the two do not seem to be working together? Also, I guess I should mention that I am using a 64-bit OS and that all installations were performed using that software requirement. I would really appreciate any help provided, because I really have a need for the Subassembly Composer.
Unfortunately, no. I have already uninstalled the SAC, simply because I have to work in Civil 3D. However, even if I reinstall it, I doubt I would be able to obtain a screen capture. The problem was simply when I tried to open Civil 3D, it would start the boot up process, get to a certain point, then just close the screen. There were no error messages or dialog boxes; the program would just close during startup. Like I stated in my original post, we tried several things to remedy the situation, but Civil3D would not open until I uninstalled the SAC. One other thing I did not mention is that when I got C3D working again the screen looked crazy and the refresh rate was really slow when I was just moving the cursor. I had to use the 3DCONFIG command to reset the hardware accelertion. Crazy...
I have consulted the Civil team and they suggested the following:
"I know that SAC required .NET 4.0 so I am not sure if this has anything to do with it if they removed SAC (will that somehow corrupt install of C3d). I would definitely try one of the two things: repair/reinstall or resetting user settings."
Reset User Settings can be found here:
http://usa.autodesk.com/getdoc/id=TS1055299
