• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    samsonthomas7606
    Problem with Plant 3D trial Install
    287 Views, 3 Replies
    09-15-2010 10:02 AM
    Our network administrator installed the Plant 3D 30-day trial on my computer( win XP SP3). When I try to run, it gives me the "AutoCAD Error Aborting". Please see attached jpeg. When administrator log on to my computer software loads fine. Any suggestion is greatly appreciated.
    Samson Thomas
    Please use plain text.
    TravisNave
    Re: Problem with Plant 3D trial Install
    09-15-2010 10:21 AM in reply to: samsonthomas7606
    Do you have local Administrator rights on your computer?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    samsonthomas7606
    09-15-2010 06:00 PM in reply to: TravisNave
    Thanks for reply.  Yes, I do have the administrator rights.
    TravisNave
    09-16-2010 07:50 AM in reply to: samsonthomas7606
    Then it could be a problem with your Windows profile.  You could have another user with local admin rights login and see if the program works.  That should narrow it down to the profile or not.
    Travis Nave
