Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Problem with LMTOOLS license server
- Highlight
- Email to a Friend
I've just installed LMTools on a new server but it's giving the following error on the server status tab:
lmgrd is not running: Cannot connect to license server system.
The license server manager (lmgrd) has not been started yet,
the wrong port@host or license file is being used, or the
port or hostname in the license file has been changed.
Server name: DC01
License path: @DC01;
FLEXnet Licensing error:-15,570
The server name is correct - anyone know how to fix this? Many thanks.
Re: Problem with LMTOOLS license server
- Highlight
- Email to a Friend
Try to see if TS1052895 can help.
JTB World - Software development and consulting
Specialities: AutoCAD, AutoCAD Architecture and Revit
http://www.jtbworld.com
JTB FlexReport - network license reports
http://www.jtbworld.com/jtbflexreport/index.htm
- Highlight
- Email to a Friend
Make sure that your NLM is set up as a service and configured to use the license file that you received from Autodesk or your Reseller. This should match the hostname and the MAC Ethernet address of the server. Also make sure that you are not blocking ports 2080 and 27000 and that you are not using IPv6 for network connectivity. Also, if you are using Server 2008 R2, there might be an issue with version 11.9 and higher. You might need to use 11.7.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensi
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Problem with LMTOOLS license server
- Highlight
- Email to a Friend
Additionally, Please try to start your service from Windows Services, see if you can start it there.
Emily Xu
AutodeskCare | Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi thanks for the suggestions, all tried but to no avail. However I am running version 11.10 on Server 2008 R2. Where can I download 11.7? And will this still work with AutoCAD 13?
- Highlight
- Email to a Friend
Would you please send me your license file to check by private message? and also make a capture of your "System Settings" in your lmtools.
Emily Xu
Autodesk, Inc.
- Highlight
- Email to a Friend
You can get the 11.7 version of adskflex.exe in either x86 or x64 at my post here:
It will work fine with Autodesk 2013 products. You can keep the remaining NLM files as 11.10 if you wish. The problem is with the adskflex.exe file.
- Highlight
- Email to a Friend
Just solveD a same problem by updating the license manager, would suggest you to try.
Try to download and install the latest license manager(11.10): http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
If your OS is windows 7 or server, please choose the IPV6 license manager.
Hope helps!
_________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
Autodesk, Inc.
