Installation & Licensing
Problem with AutoCAD now cannot re-install - URGENT
15 REPLIES 15
Message 1 of 16
766 Views, 15 Replies
AutoCAD was working fine until one day it would just not open, an error box came up and the software had disappeared for some reason.
Now when i am re-installing the software it installs fine until it attempts to install the materials section (just after installing C++ and DirectX)
It then says there is a problem with the installer and i cannot install it.
I need the software ASAP for my university course, help?
Oh, and i'm running on windows 7.
** I have attached a screen shot
15 REPLIES 15
Message 2 of 16
david.lau
Message 3 of 16
in reply to: david.lau
I have, but that's for windows vista...and the explanation doesn't really help me as i do not know what to do to edit the registry.
Message 4 of 16
david.lau
This is the solution that post is referencing:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=8254094&siteID=123112
You will need to upload the log file to Autodesk forums.
David Lau
Message 5 of 16
Here's the log as the text file...
Message 6 of 16
david.lau
There is another one that is bigger.
David Lau
Message 7 of 16
That's the only one i am given.
Message 8 of 16
david.lau
Please add this to your registry and run the installer again:
David Lau
Message 9 of 16
Ok i've just done that, i found that there was already a "Logging" string value except the value was "voicewarmupx" not "voicewarmup" so i changed it.
I still get the same problem even after making those changes.
Message 10 of 16
david.lau
There should be a larger log file now in the temp folder.
David Lau
Message 11 of 16
Here you go
Message 12 of 16
david.lau
There should be a more detailed log file in the temp folder and it will have a series of letters and numbers on it.  It will not have "AutoCAD" in it.
David Lau
Message 13 of 16
DannyHubbard
You might also try disabling the User Access Control in Windows Control Panel then try installing again.
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 14 of 16
in reply to: DannyHubbard
I'm using the administrator account so there are no issues with user access.
Here are all the log files from the latest installation attempt.
I'll add the other 3 in another post, as i don't know which you need.
Message 15 of 16
david.lau
1. Create a Standalone deployment and name the deployment:  Test
2. Then go into the Deployment\AutoCAD\2011\AdminImage.
3. Look for: Test.ini
4. Edit Test.ini and edit the following:
We are going to have the deployment not install the Material Library so that you can a least install AutoCAD.
==================== IL : Autodesk ProMaterial 2011 Library - Low Image Library
EXE_PARAM=
PATCHES=
[CMILL]
PRODUCT_NAME=Autodesk Material Library 2011 - Low Resolution
PLATFORM=ALL
EXE_PATH=echo
LOG=%tmp%\MaterialLibrary2011CMILL.log
ACTION=INSTALL
==================== IL : Autodesk ProMaterial 2011 Library - Medium Res Library
EXE_PARAM=
PATCHES=
[CMILM]
PREREQUISITE=OS;IE;CM;CMILL
PRODUCT_NAME=Autodesk Autodesk Material Library 2011 - Medium Image Library
PRODUCT_MESSAGE=AcSetupRes.dll;61
PRODUCT_ICON=
PLATFORM=ALL
EXE_PATH=echo
LOG=%tmp%\MaterialLibrary2011CMILM.log
ACTION=
REMOVE_PATH=
ROLLBACKABLE=YES
USE_EXTERNAL_UI=YES
EULA_PATH=EULA
ALLOW_ADD_REMOVE=NO
ADMIN_INSTALL=YES
5.  The typical deployment will have the .msi file location instead of echo.
David Lau
Message 16 of 16
It's not a problem anymore, i installed 2010 instead. Every single person on my course is having problems with autocad 2011.
Administrator Productivity
