• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Member
    Problem whit installation of Autodesk Material Library 2013 - Low Resolution
    1194 Views, 7 Replies
    11-13-2012 08:05 AM
    I have tried to install AutoCAD 2013, but when the setup install Autodesk Material Library 2013 - Low Resolution the installation fail.
     I'm running Windows 7 Pro 64-bit, I am admnistrator and I receive the following in the installation log file:
    2012/11/8:16:24:11 Utente UTENTE-PC === Setup started on UTENTE-PC by Utente ===
    2012/11/8:16:24:11 Utente UTENTE-PC Launch
    2012/11/8:16:24:12 Utente UTENTE-PC PageOpen LaunchDialog
    2012/11/8:16:24:23 Utente UTENTE-PC PageOpen LicenseDialog
    2012/11/8:16:24:23 Utente UTENTE-PC PageOpen ProductSelectionDialog2
    2012/11/8:16:24:27 Utente UTENTE-PC PageOpen LicenseDialog
    2012/11/8:16:24:27 Utente UTENTE-PC PageOpen LaunchDialog
    2012/11/8:16:24:28 Utente UTENTE-PC PageOpen LicenseDialog
    2012/11/8:16:24:30 Utente UTENTE-PC PageOpen ProductInfoDialog
    2012/11/8:16:24:46 Utente UTENTE-PC PageOpen ProductSelectionDialog2
    2012/11/8:16:35:36 Utente UTENTE-PC PageOpen FullProgressDialog
    2012/11/8:16:35:36 Utente UTENTE-PC Installing DirectX Runtime: D:\3rdParty\DirectX\DXSETUP.exe /silent
    2012/11/8:16:35:53 Utente UTENTE-PC Install DirectX Runtime Succeeded
    2012/11/8:16:35:54 Utente UTENTE-PC Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Utente\AppData\Local\Temp\_AI69B0.tmp\Media.mst"
    2012/11/8:16:36:05 Utente UTENTE-PC Install Autodesk Material Library 2013 Succeeded
    2012/11/8:16:36:06 Utente UTENTE-PC Installing Autodesk Material Library 2013 - Low Resolution: ADSK_EULA_STATUS=#1 MUILANG=it-it ADSK_SOURCE_ROOT="D:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\Utente\AppData\Local\Temp\_AI69B0.tmp\Media.mst"
    2012/11/8:16:39:36 Utente UTENTE-PC Install Autodesk Material Library 2013 - Low Resolution Failed Installation aborted, Result=1603
    2012/11/8:16:39:44 Utente UTENTE-PC Rollback Autodesk Material Library 2013 Succeeded
    2012/11/8:16:39:44 Utente UTENTE-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
    Please use plain text.
    Product Support
    Re: Problem whit installation of Autodesk Material Library 2013 - Low Resolution
    11-13-2012 03:06 PM in reply to: klausco
    Hi there,
    Go ahead and try installing the libraries on thier own by running the MSI files directly and see if they will install that way. If you downloaded the installer they should be in the below directories
    C:\Autodesk\AutoCAD_2013_English_Win_32-64bit\Content\ADSKMaterials\2013\CM\MaterialLibrary2013.msi
    C:\Autodesk\AutoCAD_2013_English_Win_32-64bit\Content\ADSKMaterials\2013\ILB\BaseImageLibrary2013.msi
    If you are installing from a disc the folders are basicly the same but you will need to expore into your DVD drive and find them
    Once you have run both MSIs and have installed all the libraries try installing AutoCAD again.
    Member
    11-14-2012 02:31 PM in reply to: klausco
    I have installed MaterialLibrary2013.msi with success, but when I instaln BaseImageLibrary2013.msi I get an error: "The library could not be installed/uninstalled. Please exit all running application and try again".
    I have disabled antivirus realtime guard,  I have closed many processess, but  BaseImageLibrary2013.msi installation still fails.
    Product Support
    11-15-2012 09:46 AM in reply to: klausco
    When you look on your programs and features control panel does an entry already exist for the Autodesk material library Base resolution library 2013? If so please try and uninstall it and re-install from the MSI.
    Member
    12-04-2012 12:08 AM in reply to: asburyj
    Asbury, you are great!!!
    I finally installed autocad.
    Now I have another problem, when I launch AutoCAD, it opens for a moment and then it crashes.
    Attacched two files, Report.txt with error report and event_log.txt whit windows event log.
    Product Support
    12-04-2012 08:20 AM in reply to: klausco
    I'm sorry to hear you are still having trouble. I can't pinpoint the cause of your crash from that even log but I would suggest you try the following steps.
    1.) Update your video card driver to the latest version available from your video card manufacturer.
    2. )In your programs and features control panel repair your installation of microsoft .net framework 4.0 client and extended
    3.) Try to reset your AutoCAD settings using the reset settings to default tool (http://upandready.typepad.com/up_and_ready/2012/07/the-easiest-way-to-reset-autocad.html)
    Member
    Autocad LT 2013 crash
    12-04-2012 01:48 PM in reply to: klausco
    I did the steps you suggested, but the problem remains.
    When I run autocad, after loading everything, it closes.
    If I open a file, it opens but when you see the menu bar, the program closes.
    How can I check if my graphics card is incompatible??
    Help me !!!!
    Product Support
    Re: Autocad LT 2013 crash
    12-04-2012 01:54 PM in reply to: klausco
    The list of hardware tested and certified by Autodesk can be found at the below site.
    http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
