• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    mtermeer
    Problem transferring licence from old PC to new PC.
    270 Views, 1 Replies
    01-10-2012 08:21 AM
    Hi, We need to transfer the AutoCAD LT2009 licencekey from an old PC to a new PC. We used the Portable Licence Utility, but unfortunately the import in the new PC doesn't work. The error code is [17.1.84]. This file is not a valid transfer file. So, on the old PC we get a message that the export was successful, but on the new PC we get the error. Besides that we now have on the old PC a problem that the licencekey isn't active any more and we can't use AutoCAD any more. Please advice how to solve this issue. (screenshots are available). Thanx in advance! Greetz, Mathieu
    Please use plain text.
    Product Support
    INACTIVE_Timmy.DeAustria
    Re: Problem transferring license from old PC to new PC.
    01-10-2012 09:06 AM in reply to: mtermeer
    I do not know if "License Transfer Utility" will work with 2009, but you can try.
    You will need an Internet Connection, and an Autodesk user ID and password, available from the Autodesk Register Once website:
    https://registeronce.autodesk.com
    More information about the "License Transfer Utility" can be found here:
    http://docs.autodesk.com/ACD/2011/ENU/filesLIC/WS1a9193826455f5ff-3859b43c1209703a838e77.htm
    For detailed instructions on how to export your license using License Transfer Utility can be found here:
    http://docs.autodesk.com/ACD/2011/ENU/filesLIC/WS1a9193826455f5ff-3859b43c1209703a838-4865.htm
    For detailed instructions on how to import your license using License Transfer Utility can be found here:
    http://docs.autodesk.com/ACD/2011/ENU/filesLIC/WS1a9193826455f5ff-3859b43c1209703a838-484c.htm
    For a video guide on how to use License Transfer Utility, please follow this link:
    http://usa.autodesk.com/getdoc/id=TS13409518
    If you cannot use the License Transfer utility, you need to contact Autodesk Product Registration and Authorization Customer Service
    Email: authcodes@autodesk.com
    Phone: 1-800-551-1490
    Hope this helps...
    Timmy De Austria
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
