• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    cepegra
    Accepted Solution
    Problem licensing server maya 2013
    476 Views, 2 Replies
    09-05-2012 05:57 AM
    I have download maya 2013 and installed the licensing server. But it is impossible to receive a license /
    The client receive
    A valid license could not be obtained by the network license manager  error -15.570.0
    in the licensing server, I received the information in perform diagnostics :
    this license cannot be checked out because: a PACKAGE componennt must be specified. Flexnet licensing error -125,147
    Thank you
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Problem licensing server maya 2013
    09-05-2012 08:45 AM in reply to: cepegra
    The diagnostics is misleading.  Do not use that functionality in the LMTOOLS.
    Assuming you got the license .LIC file from Autodesk/Reseller and configured LMTOOLS properly, you should be in good shape.  If the license manager and the client are on the same machine, then you're likely experiencing an IPv6 issue or firewall port blocking.  This is especially true on Windows 7 or Server 2008 installations.
    For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    11-16-2012 02:36 AM in reply to: cepegra
    I had this problem. Turning the firewall off on the license server solved it. It was only the remote clients that were having this problem.
