Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Problem licensing server maya 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have download maya 2013 and installed the licensing server. But it is impossible to receive a license /
The client receive
A valid license could not be obtained by the network license manager error -15.570.0
in the licensing server, I received the information in perform diagnostics :
this license cannot be checked out because: a PACKAGE componennt must be specified. Flexnet licensing error -125,147
Thank you
Re: Problem licensing server maya 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The diagnostics is misleading. Do not use that functionality in the LMTOOLS.
Assuming you got the license .LIC file from Autodesk/Reseller and configured LMTOOLS properly, you should be in good shape. If the license manager and the client are on the same machine, then you're likely experiencing an IPv6 issue or firewall port blocking. This is especially true on Windows 7 or Server 2008 installations.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensi
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Problem licensing server maya 2013
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
