Installation & Licensing
Problem installing inventor 2011
5 REPLIES 5
769 Views, 5 Replies
IM trying to install the student version of inventor 2011, when the first file is downloaded a window appears telling me that some of the files already exist, probably cause I've tried to download it several times, so I just click the option  "replace existing files", then I click the install button everything seems to be OK until the end when I get another window that say
 "you need to have the following volume to continue extraction: autocad_inventor_suite 2011_win_32bit.part2(1).
insert a disk with the volume and press ok to try again or press cancel to break the extraction"
what do i do to continue with the installation?
5 REPLIES 5
david.lau
Can you download the 2012 version? It appears you are missing a part of the download.
David Lau
I need to have the 2012 version because thats the one we use in class. But i did get 3 files downloaded and still get a message telling me that some files are corrupt
I meant 2011
KevinHu_PDMS_Vault
please make sure you save all the compress files in the same folder.  you can try to unzip the files by other tool. such as wrar or winzip.
if you still encounter the error, change another machine and download 2011 and have a try again.
in reply to: KevinHu_PDMS_Vault
have you tried to download winrar 64-bit, that helped me.
Administrator Productivity
