Installation & Licensing
Problem installing Revit 2014 (student version)
10 REPLIES 10
Message 1 of 11
3638 Views, 10 Replies
Hello Guys,
I had a problem in my laptop and I had to reinstall my windows.
Now, I am facing a problem on the installation of Revit 2014 (student version).
I have been trying too many things attempting to fix this problem, I have no luck. Man Sad
I uninstalled so many times the "Microsoft Microsoft Visual C++" 2005 and all other versions 2008/2010. through Panel Control and also another tool called "dotnetfx_cleanup_tool" etc...I dont know what to do.
I had a similar issue when I was installing Autocad Architecture 2014 but I solved removing Microsoft .net 4.5 and installiing 4.0 version.
If someone could clarify what is going on and how to solve it, I appreciate.
10 REPLIES 10
Message 2 of 11
JoAnn_Hogan
Please ensure the following has been done:
1. Computer meets the minimum requirements
2. UAC off
3. Firewall off
4. Anti-Virus off
5. Administrator rights
6. Clear the temp folder
7. Make sure you have enough disc space 60 Gigs at least
8. Make sure the OS is up to date
9. Reinstall C++ redistributable
10. Reinstall .Net Framework
11. Copy the content of the installation media to the C drive. Preferably on the root of the C drive to negate the problem of filenames becoming too long
12. Make sure short file name creation has been enabled HKEY_LOCAL_MACHINE\SYSTEM\
CurrentControlSet\Control\FileSystem Set NtfsDisable8dot3NameCreation to a value of 0
13. Create a new Windows user with full admin rights
14. If the computer is on a domain remove it from the network completely for the duration of installation
Let me know if there is a step you dont know how to do. If that still does not work, please let me know so I could continue to trouble shoot your issue. Have you tried downloading a trial version and licensing it afterwards?
If this post solved your issue please mark as solved and Kudos are always welcome 😃
Jo - Ann
Twitter: @JoAnn_Hogan
Revit Architecture Certified Professional / Revit Structure Certified Professional / AutoCAD Certified Professional
Message 3 of 11
in reply to: JoAnn_Hogan
Hello Joann,
I really thank you for the message. I solved my problem after checking your list.
Anti-Virus Off
UAC Off
Cleaned temp folder
I needed to update my OS as I had reinstalled the system.
and I changed the value on step 12 to "0"
Done!!!
I appreciated your attention.
Now I can work quietly on my university projects!
Have a good day,
Guilherme Macedo Monteiro
Message 4 of 11
JoAnn_Hogan
Its a pleasure. I am glad I could help. 😃
Jo - Ann
Message 5 of 11
mohuk2007
I am trying to install the educational version of Revit 2014,
It keeps saying communication failure,
I have tried it over a 100 times, something most be wrong.
Kindly advise please.
Message 6 of 11
JoAnn_Hogan
in reply to: mohuk2007
Hi Mohuk,
Please post this as a new issue. It will help us to see if it is resolved or not.
Kindy follow this link to create a new issue: http://forums.autodesk.com/t5/forums/postpage/board-id/24
Jo - Ann
Message 7 of 11
jric164
How do you do numbers 11 and 12?
Message 8 of 11
knseo
Message 9 of 11
wt012929
Hi there, I have been trying and failing to download the student versions of Revit 2014, 2015 and 2016 as it says that I do not have minimum system requirements of windows 8 when I currently have windows 10 on my laptop.
Is there any way I can resolve this as I need this system for my degree at university?
Message 10 of 11
camilo.lemos
in reply to: wt012929
Hi @wt012929 and welcome to the Autodesk Community!
Revit 2014 is not supported on Windows 10. Please see more information here.
I suggest trying to install using Windows Compatibility Mode.
I hope this helps!
Camilo Lemos
Message 11 of 11
wt012929
in reply to: camilo.lemos
I tried doing this and it still says that revit cannot download due to inadequate system requirements. I tried this with revit 2014, 2015 and 2016 versions and still cannot download onto my laptop. Anything else I can try? Thanks
Sent from Mail for Windows 10
Administrator Productivity
