Installation & Licensing
Problem installing Inventor View 2013
2 REPLIES 2
getgetdown
762 Views, 2 Replies
I have a problem when I lanch the installation of Autodesk Inventor View 2013.
The error is "Can't find End User License Agreements" and the installation closes.
I have tried both English and Italian version, same error.
Any ideas?
Regards.
2 REPLIES 2
Darin.Green
in reply to: getgetdown
Try clearing out your temp directory.
If this information was helpful, please consider using the Accept Solution
dembkod
You can clear your temp directory by clicking the Windows Start button and in the run box type %TEMP% and press [Enter]. Delete everything the system will let you delete. Also, make sure Antivirus is off and you are logged in as an Admin. You can also use a new download in case the original install files are corrupt… which sounds possible based on your description.
Thank you for taking part in our community!
Thank you,
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
Administrator Productivity
