Installation & Licensing
Problem installing AutoDesk Inventor 2012
2 REPLIES 2
junting.yeung
426 Views, 2 Replies
When I try to install AutoDesk Inventor, they say that I need
Microsoft hotfix 971138 required for Inventor to function fully with Vista Operating Systems"
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16323149&linkID=9242018
They give me a support link to fix the Microsoft hotfix 971138.
http://support.microsoft.com/kb/971138
However, there is nothing to download on the link.
My system:
I have 6002: System Pack 2
 Manufacturer: Hewlett-Packard
   Model: HP Pavilion dv2 Notebook PC
   The total amount of system memory: 2.00 GB RAM
   System type: 32-bit operating system
   Number of processor cores: 1
What should I Do?
2 REPLIES 2
RogerMollon
in reply to: junting.yeung
junting.yeung,
Please see if the information in this other discussion group thread helps:
http://forums.autodesk.com/t5/Autodesk-Inventor/Hotfix-Kb971138-Download-for-Vista/m-p/2998212/highl...
Thank you,
Roger Mollon
Forge - Strategic Tech Consultant - Novi
Autodesk, Inc. - Retired
TravisNave
Please see my link here for a direct download without a password:
http://forums.autodesk.com/t5/Installation-Licensing/Email-with-hotfix-for-inventor-has-no-password/...
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
Autodesk Forums:
Administrator Productivity
