Installation & Licensing
Problem installing 3Ds Max 2011
21 REPLIES 21
Message 1 of 22
9776 Views, 21 Replies
Im trying to install the student version of 3D Max 2011 and every time I try to instal it a new Error message comes up stating that a source file was not found (help.cab)..it says I have to verify that it exists... i really dont know what this file is) this also happend last time i installed 2010 over a year ago and i talked to someone at costumer support by phone but know they told me there is no phone support anymore?.. any help installing the software>
thanks..
Tags (1)
21 REPLIES 21
Message 2 of 22
DouglasLauritsen
This .cab file is found in the <<DOWNLOADorMEDIA>>\x64\max folder. It may be that the extraction from the download or DVD has a problem. If it is a DVD try copying the media to the local hard drive and run from there. It may also be that your temp folder is full and needs to be emptied.
Douglas Lauritsen
Support Specialist
Product Support
Message 3 of 22
I've downloaded the student version from your website. I also got the same problem with the help.cab file. I've searched in the folders, but no help.cab file can be found.
Is there a possibility to download the single help file?
I've downloaded 3Ds Max twice with the same problem.
I've read about the problem in different forums, but never get any solution.
Thanks for your kind help.
Message 4 of 22
I am having the same problem. The file is not there in x64/max or x86/max
Message 5 of 22
Thanks for your file. I downloaded it and insert it in the "max"-folder of the 32-bit version.
But now when I try to install the error 1334 appears.
It says that the file "ICO_FILE3DSMAXANT.CCD232C8.9237_47E1...." could'nt be installed, because this file isn't founded in the cabinet-data file "help.cab". That points out that there is a network-error, a CD-Rom-error or that the packet has a problem.
I don't know what I should do now.
Message 6 of 22
DarrenP
i don't see that in my .cab file and my max 2011 works fine
DarrenP
Message 7 of 22
DouglasLauritsen
in reply to: DarrenP
Download the files again using an alternative download. I’d suggest using the Browser download button from Firefox from Subscription Center. For the Student Community Download pages click the link lower on the page for those having problems with the Akamai Download Manager. You may be behind a Proxy or be on a network with settings that Akamai may not work well on.
     http://forums.autodesk.com/t5/Installation-Licensing/Tips-on-the-use-of-the-downloaded-product-files...
Douglas Lauritsen
Support Specialist
Product Support
Message 8 of 22
in reply to: DouglasLauritsen
i am new studen and i downloaded 3ds max 2011 , but while installing it , it occured same problem as specified above. Can anyone plz provide me the file named help.cab please
Message 9 of 22
Hey,
I've also downloaded the student version from your website. I also got the same problem with the help.cab file. I've searched in the folders, but no help.cab file can be found on my computer at all.
IIs it possible to grab it as a single file?
I have searched and searched for solutions, and have not found any yet, and the previously posted solution doesnt seem to help 🙂
Kind Regards,
  Chris
Message 10 of 22
Same, see my attachment.
I have:
1) Downloaded it on 2 different pc's at different locations, both with there security switched off
2) Tried unarcing the rar with 7zip and it suggests an error in x64\max\max7.cab
3) Tried installing both 32 and 64 bit, same error comes up
4) Tried both links
5) Downloaded several times
6) Tried different browsers
I'm not convinced this is down to transmission or security, in my opinion there is something wrong with the package
Tags (1)
Message 11 of 22
I reckon I know whats going on here. Attached is a winrar test on the part 2 archive.
I haven't downloaded part 1 yet due to bandwidth, so I reckon from the error message that you have to unarc both packages before you even start installation - i.e. you HAVE to have both extracted
I will report back when I have downloaded and unarc'd both packages
Message 12 of 22
tonnekloppen
same here...help.cab missing. I also noticed, that the downloaded .rar is named "part2", but of what? Downloaded it twice (with my browser, not with the DL-Manager) and never had the option to download a "part1"...
Message 13 of 22
In the downloads section you are given the option of:
"If you are having trouble with your download, please click here to download using your browser. "
You can then download them to your desktop instead of some random temp file denoted by the "Installer"
I'm currently downloading Part 1 now (3GB)...
Message 14 of 22
Solved
download both packages and then installed from part one. Works fine
Autodesk  - would be worth suggesting you MUST download both pakages
Message 15 of 22
to be honest this is a real pain in the ****, has anyone found a solution to this problem?
Message 16 of 22
When I downloaded it through the "Browser Download" option with Google Chrome in the default and same directory(because "download now" or "Install Now" Options were not available for any software, And it took more than 18 hours to get downloaded)and when I launch the Setup File that ends in .exe this popped up and installation was Absolutely unsuccessful:
The System Cannot find the file specified.
C:\Autodesk\Autodesk_3ds_Max_2011_English_Win_32-64bit\SetupRes\eval.msi
And Then The Installer Closes Absolutely Unsuccessful. Please Help, This A Very Important Emergency, Please Reply Detailed Illustrations, Please Hurry, Reply Back As Soon As You See This, And Thank You If You Help!
Message 17 of 22
celine.manca
Hi strongzed,
You can find a direct download link for Autodesk 3ds Max 2011 in our Virtual Agent.
1. Click on Downloading New/Updated Products
2. Click the first hyperlink to download prior to 2014 release
3. Select product and version you need
Celine Manca
Message 18 of 22
DarrenP
in reply to: celine.manca
read this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21889889&linkID=9243099&CMP=OTC-RSS...
DarrenP
Message 19 of 22
Thanks, but when I downloaded a fresh copy again from that place, and after 18 hours of download when I ran the install file on my desktop It installed a little files and said:
Error
Some installations files are corrupted.
Please download a fresh copy and retry the installation.
And then the installation automatically aborted.
And still after that when I ran the setup file (Which it installed) it said the same thing I told the previous time. Any Help? It's an Emergency!
Message 20 of 22
philip.s
Hi Alex,
Corrupt download issues / CRC errors are typically resolved by utilizing a different browser, and/or turning off your firewall + antivirus software.
Can you please give that a shot and let us know if it makes a difference?
Administrator Productivity
