I want to work( I'm a charged student ^^) but everytime I try to install 3DS Max everything in the package fail to install
Here is a screenshot: http://puu.sh/8V3UW.jpg
My log :
2014/5/21:06:47:56 Utilisateur UTILISATEUR-PC === Setup started on UTILISATEUR-PC by Utilisateur ===
2014/5/21:06:47:56 Utilisateur UTILISATEUR-PC Path_Length: 151
2014/5/21:06:47:56 Utilisateur UTILISATEUR-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_fr-FR
2014/5/21:06:47:56 Utilisateur UTILISATEUR-PC Launch
2014/5/21:06:47:56 Utilisateur UTILISATEUR-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_fr... /SN 900-39232682 /PK 128F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/5/21:06:47:56 Utilisateur UTILISATEUR-PC Current Directory C:\Users\UTILIS~1\AppData\Local\Temp\_AI842D.tmp
2014/5/21:06:49:01 Utilisateur UTILISATEUR-PC === Setup ended ===
2014/5/21:06:47:57 Utilisateur UTILISATEUR-PC === Setup started on UTILISATEUR-PC by Utilisateur ===
2014/5/21:06:47:57 Utilisateur UTILISATEUR-PC Path_Length: 151
2014/5/21:06:47:57 Utilisateur UTILISATEUR-PC Current Directory C:\Users\UTILIS~1\AppData\Local\Temp\_AI842D.tmp
2014/5/21:06:47:57 Utilisateur UTILISATEUR-PC Launch
2014/5/21:06:47:58 Utilisateur UTILISATEUR-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2014/5/21:06:49:00 Utilisateur UTILISATEUR-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2014/5/21:06:49:00 Utilisateur UTILISATEUR-PC PageOpen LaunchDialog
2014/5/21:06:50:31 Utilisateur UTILISATEUR-PC PageOpen LicenseDialog
2014/5/21:06:50:31 Utilisateur UTILISATEUR-PC PageOpen ProductInfoDialog
2014/5/21:06:50:31 Utilisateur UTILISATEUR-PC PageOpen ProductSelectionDialog2
2014/5/21:07:01:25 Utilisateur UTILISATEUR-PC PageOpen FullProgressDialog
2014/5/21:07:01:26 Utilisateur UTILISATEUR-PC Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2014/5/21:07:01:27 Utilisateur UTILISATEUR-PC Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2014/5/21:07:01:27 Utilisateur UTILISATEUR-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\UTILIS~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/21:07:01:29 Utilisateur UTILISATEUR-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/5/21:07:01:30 Utilisateur UTILISATEUR-PC PageOpen InstallCompleteDialog
2014/5/21:07:02:27 Utilisateur UTILISATEUR-PC === Setup ended ===
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC === Setup started on UTILISATEUR-PC by Utilisateur ===
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC Path_Length: 151
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_fr-FR
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC Launch
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_fr... /SN 900-39232682 /PK 128F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC Current Directory C:\Users\UTILIS~1\AppData\Local\Temp\_AI90BB.tmp
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC === Setup ended ===
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2014/5/21:07:06:34 Utilisateur UTILISATEUR-PC PageOpen LaunchDialog
2014/5/21:07:06:38 Utilisateur UTILISATEUR-PC PageOpen LicenseDialog
2014/5/21:07:06:38 Utilisateur UTILISATEUR-PC PageOpen ProductInfoDialog
2014/5/21:07:06:38 Utilisateur UTILISATEUR-PC PageOpen ProductSelectionDialog2
2014/5/21:07:07:00 Utilisateur UTILISATEUR-PC PageOpen FullProgressDialog
2014/5/21:07:07:00 Utilisateur UTILISATEUR-PC Download Skipped VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2014/5/21:07:07:00 Utilisateur UTILISATEUR-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\UTILIS~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/21:07:07:01 Utilisateur UTILISATEUR-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2014/5/21:07:07:02 Utilisateur UTILISATEUR-PC PageOpen InstallCompleteDialog
2014/5/21:07:12:29 Utilisateur UTILISATEUR-PC === Setup ended ===
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC === Setup started on UTILISATEUR-PC by Utilisateur ===
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC Path_Length: 151
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC Launch
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en... /SN 900-39232682 /PK 128F1 /student /akamai /skipEULA /auth authparam /sid SESSION_ID
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC Current Directory C:\Users\UTILIS~1\AppData\Local\Temp\_AIE89A.tmp
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC === Setup ended ===
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/SETUP...
2014/5/21:07:14:35 Utilisateur UTILISATEUR-PC PageOpen LaunchDialog
2014/5/21:07:14:38 Utilisateur UTILISATEUR-PC PageOpen LicenseDialog
2014/5/21:07:14:38 Utilisateur UTILISATEUR-PC PageOpen ProductInfoDialog
2014/5/21:07:14:38 Utilisateur UTILISATEUR-PC PageOpen ProductSelectionDialog2
2014/5/21:07:14:42 Utilisateur UTILISATEUR-PC PageOpen FullProgressDialog
2014/5/21:07:14:43 Utilisateur UTILISATEUR-PC Download Skipped VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/EDU/{032D0276-0263-4DDF-AFC2-758A83024F4F}/VCRED...
2014/5/21:07:14:43 Utilisateur UTILISATEUR-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\UTILIS~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/5/21:07:14:44 Utilisateur UTILISATEUR-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
If the prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
