Installation & Licensing
Problem getting license
8 REPLIES 8
Message 1 of 9
401 Views, 8 Replies
I can not get a license for the workstation. When I do a server status I
get the following message at the end:
Users of 41100ACD_2002_0F: (Error: 7 licenses, unsupported by licensed
server)
I can not seem to figure out what is wrong. Any Ideas?
Paul
8 REPLIES 8
Message 2 of 9
Paul -
There is a problem with your adlm.
Stop the adlm service and restart it. Wait a couple of minutes and check the debug.log to try and see what exactly the problem is.
Post the contents of the debug.log if you'd like and we'll try to help you figure out what is going on.
jason
"Paul E. Otto" wrote in message news:2B2875E0C5C5AB20CFAED8881142A707@in.WebX.maYIadrTaRb...
> server)
> Paul
Message 3 of 9
Jason -
Thanks for the quick response. Here is the results of the log file:
9:01:48 (lmgrd) Detecting other lmgrd processes...
9:02:03 (lmgrd) FLEXlm (v7.1f) started on SERVER (IBM PC) (11/7/2001)
9:02:03 (lmgrd) FLEXlm Copyright 1988-2000, Globetrotter Software, Inc.
9:02:03 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:02:03 (lmgrd) World Wide Web: http://www.globetrotter.com
9:02:03 (lmgrd) License file(s): C:\flexlm\license.dat
9:02:03 (lmgrd) lmgrd tcp-port 27000
9:02:03 (lmgrd) Starting vendor daemons ...
9:02:03 (lmgrd) License daemon startup failed:
9:02:03 (lmgrd) File not found, port
9:02:03 (lmgrd) Started adskflex (pid 426)
9:02:03 (adskflex) cannot establish lock - exiting (file:
C:\flexlm\adskflex, errno: 13)
"jason martin" wrote in message
news:6FDE96DF14EDD0D0766106F5B6908846@in.WebX.maYIadrTaRb...
> Paul -
> jason
Message 4 of 9
Paul -
It looks like there could be a problem with your license file?? The lines
worry me.
Could you post a copy of your c:\flexlm\license.dat file???
jason
"Paul E. Otto" wrote in message news:2331D574C57BA33BB199527FFB82654E@in.WebX.maYIadrTaRb...
> Jason -
Message 5 of 9
SERVER SERVER 00104B6D1910
USE_SERVER
VENDOR adskflex port 80
INCREMENT 41100ACD_2002_0F adskflex 1.000 permanent 7 \
VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=H \
ISSUED=1-jul-2001 ck= SN=0-32957503 SIGN=5A75202D22
news:15AE2AB9E155C06E55A2E923BE2B4147@in.WebX.maYIadrTaRb...
> Paul -
> worry me.
> jason
Message 6 of 9
It doesn't look quite like mine. What that means, I don't know. I'm also on
a different port for some reason. That might be causing problems. Ain't it
cool that we can post these since they're tied to the mac address?
SERVER JBI-W2K-SERVER 0050DABACB48
USE_SERVER
VENDOR adskflex port=2080
INCREMENT 41100ACD_2002_0F adskflex 1.000 permanent 4 \
ISSUED=30-aug-2001 ck=186 SN=400-32919774 SIGN=A46088FA0A7C
James Wedding
IT Manager
Jones & Boyd, Inc.
Dallas, TX
jwedding@*NOSPAM*jones-boyd.com
Message 7 of 9
Okay, there are some serious problems with your license file.
USE_SERVER
ISSUED=1-jul-2001 ck=*** SN=**0-32957503 SIGN=**5A75202D22
See if you can find the original copy of the license file that autodesk sent you. The vendor string was incorrect, it had lost =20
between the t and the 8. The check sum appears to have been ripped out (although I'm not sure that it is required). Some of the
serial number digits are missing, and I think that you are missing 2 digits from the SIGN, which is the special secret code
generated by autodesk so that I can't create my own license files.
If the email that autodesk sent you matches your license file, then you'll need to call them again and have them send a new one,
cause this one won't work.
hth
jason
"Paul E. Otto" wrote in message news:93B7B814C222EFEBD3F50836F679E4AC@in.WebX.maYIadrTaRb...
> USE_SERVER
> > Paul -
> > worry me.
> > jason
Message 8 of 9
It sure helps to post and try to figure out problems.
My old ADLM is using port 1422, does this matter. By the way I am using a
NT SP6 machine and am also running adlm server for acad 2000i. If it
matters. Thanks
Message 9 of 9
Thanks for the help. I could not see what I was doing wrong and it appears
I may not have been doing anything wrong. That is how it came from
AutoDesk, must have gotten messed up in the email somehow.
news:08D2F813E3BEB14545B6F4FE84348FB7@in.WebX.maYIadrTaRb...
> USE_SERVER
> hth
> jason
Administrator Productivity
