Okay, there are some serious problems with your license file.
SERVER SERVER 00104B6D1910
USE_SERVER
VENDOR adskflex port=2080
INCREMENT 41100ACD_2002_0F adskflex 1.000 permanent 7 \
VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=H \
ISSUED=1-jul-2001 ck=*** SN=**0-32957503 SIGN=**5A75202D22
See if you can find the original copy of the license file that autodesk sent you. The vendor string was incorrect, it had lost =20
between the t and the 8. The check sum appears to have been ripped out (although I'm not sure that it is required). Some of the
serial number digits are missing, and I think that you are missing 2 digits from the SIGN, which is the special secret code
generated by autodesk so that I can't create my own license files.
If the email that autodesk sent you matches your license file, then you'll need to call them again and have them send a new one,
cause this one won't work.
hth
jason
"Paul E. Otto"
wrote in message news:93B7B814C222EFEBD3F50836F679E4AC@in.WebX.maYIadrTaRb...
> USE_SERVER
> VENDOR adskflex port 80
> ISSUED=1-jul-2001 ck= SN=0-32957503 SIGN=5A75202D22
> "jason martin" wrote in message
> news:15AE2AB9E155C06E55A2E923BE2B4147@in.WebX.maYIadrTaRb...
> > Paul -
> > It looks like there could be a problem with your license file?? The lines
> > > 9:02:03 (lmgrd) License daemon startup failed:
> > > 9:02:03 (lmgrd) File not found, port
> > worry me.
> > Could you post a copy of your c:\flexlm\license.dat file???
> > jason
