At the middle of the installation of Autodesk Softimage 2013 I get that error !
"An error occured while installing this product.For more information view the installation log file"
But I can't understand what's the error in the log file..!
2013/9/30:22:47:22 Warriorsam WARRIORSAM-PC === Setup started on WARRIORSAM-PC by Warriorsam ===
2013/9/30:22:47:22 Warriorsam WARRIORSAM-PC Launch
2013/9/30:22:47:31 Warriorsam WARRIORSAM-PC === Setup ended ===
2013/9/30:22:47:25 Warriorsam WARRIORSAM-PC === Setup started on WARRIORSAM-PC by Warriorsam ===
2013/9/30:22:47:25 Warriorsam WARRIORSAM-PC Launch
2013/9/30:22:47:32 Warriorsam WARRIORSAM-PC PageOpen LaunchDialog
2013/9/30:22:47:40 Warriorsam WARRIORSAM-PC PageOpen LicenseDialog
2013/9/30:22:47:43 Warriorsam WARRIORSAM-PC PageOpen ProductInfoDialog
2013/9/30:22:48:58 Warriorsam WARRIORSAM-PC PageOpen ProductSelectionDialog2
2013/9/30:22:49:32 Warriorsam WARRIORSAM-PC PageOpen FullProgressDialog
2013/9/30:22:49:32 Warriorsam WARRIORSAM-PC Installing Autodesk Softimage 2013 64-bit: TRANSFORMS="C:\Users\WARRIO~1\AppData\Local\Temp\_AIAFC7.tmp\x64\Softimage\Softimage-2013-x64-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-US ADSK_SOURCE_ROOT="F:\" INSTALLDIR="A:\Programmes installés\Softimage 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/9/30:22:56:52 Warriorsam WARRIORSAM-PC Install Autodesk Softimage 2013 64-bit Failed Installation aborted, Result=1603
If you can help me .. Thank you 🙂
Sorry to hear that you encounter issue with the installation of "Autodesk Softimage 2013".
Try to manually remove the VC++ and DotNet components from your computer from "uninstall or change a program" and reattempt the installation.
If it still fails, append the "setup.ini" file you use for the installation which is located in the same directory as the "Install.exe" and a Print screen of the error message.
For your information, make always sure to run the installation with Admin right and the antivirus deactivated.
Hello
Same problem afther what you told me in the other message !
I put the setup.ini file in attachments!
Thank you!
What sticks out to me is that your installation folder is listed as A:\ drive. That's odd...
