I want to activate my trial version after we`ve recived the full version at work. But when I enter the product key it tells me that the product key is wrong. Also tried to uninstall Revit 2013 and reinstalling it with our license server, but when I start Revit I get the same window that tells me this is an trial version and I have 19 days left og my period.
As Revit 2013 is exclusively available through one of the suites (outside of the Education Community), the correct Product Key is 765E1 (Building Design Suite Premium) or 766E1 (Building Design Suite Ultimate).
Please let me know if you're still experiencing issues or accept as a solution so that others can easily benefit from the information.
Well that helped in a way, but I`m using a licens server, now I only got to a point where I neede an activation key, which I don`t have. I`ve tried several times to uninstall Revit, but after installing it Revit still think I`m using this trial version. It seems like there`s something in the registry that isn`t removed completely.
Hi eirik_nordvik:
Could you please send us your serial number through private message? We will need to check further on your activation request. For license server, please also include a host ID and server name if its available.
Best Regards,
OK, how do I send a private message. This is my first time in this discussion groups.
You click on the username on the left side, then click to send a priviate message listed on the right side of their profile page.
Or you can click here.
OK, but I found av way around. I uninstalled the trial version, and then searched for "Revit 2013" and "Revit_2013" in the registry and deleted all I could find (it took about an hour)
Then I installed Revit again and this time it didn`t start the trial version. So finally the problem is solved.
