Hello, first of all i'm sorry for my english (it's not my main lenguage)
Now the problem:
System: Windows 7 64BIT.
This is what happens when i trying to install the program..
Iv'e allready tried to uninstall "Microsoft visual c++" like 10 times..
1. Uninstall and install the newer.
2. Uninstall and let 3Dmax installer to install "microsoft visua.."
3. Uninstall and install "Microsoft visual c++ 2010"
Tried redownload and download with client / direct.
Tried to restart the computer
I'm run owt of ideas :'(
I'ts all running perfectly untill the "installing" time..
There it's stops and thath's what heppens:
Iv'e got also log file that i attached to the message.
Your product is failing to install because the prerequiste program required by the installer is failing prior to the installation of your Autodesk software.
Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
If the prerequisite program already exists on your computer, it is likely newer than the one the Autodesk installer is attempting to install. Please uninstall the prerequisite program causing the issue and run your installer again.
For more information about this process, please see my KB link here:
http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
The prerequisite is not already installed and installation still fails, then you may need to make an advanced edit to the setup.ini file to ignore the error. Please make sure you manually install the prerequisite file from Microsoft and then modify the setup.ini file accordingly.
For more information on this process, please see my KB article here:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
