Installation & Licensing
Problem Deployment AutoCAD 2010 with SCCM 2007 SP2
1 REPLY 1
VRosselet
466 Views, 1 Reply
I have a problem when I run the deployment of AutoCAD 2010 with SCCM. It is not possible to launch the deployment if I am not connected with an administrator account. The workstations are installed with Windows 7 Enterprise 32-bit. When I run the SCCM 2007 SP2 Deployment (prepared as directed by Autodesk) as a standard user, an error message appears and tells me that the copy functions can not be used. The process then seems to run in a loop and nothing happens. There is no specific information in the LOG file.
Is it due to the unfriendly security of Windows 7 (the UAC is disabled)? This problem is known? Should it be mandatory to be connected with an administrator account?
If someone has a suggestion it is welcome.
Vincent
1 REPLY 1
Hi Vincent,
I have some questions for you on this:
  • Are you letting this run as part of the scheduling or manually?
  • Is your collection a collection of users or systems?
  • Are you using the command line as it is in the documentation?
Douglas Lauritsen, Autodesk Product Support
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Administrator Productivity
