Hi, back when I was installing TrueView and Design Review 2009 in order for it to work using a script I had to also silently install several pre-req programs. Is this still the case with 2011, or can I now just run the msi install silently and it will also install any pre-req software needs?
Solved by hashim.mundol. Go to Solution.
Documented method for design review is here.
http://images.autodesk.com/adsk/files/adr2011_install_guide.htm#InstallADRSilent
For Trueview 2011 following command line seems to work; might work for design review too.
installsource\setup.exe /w /t /q setup.ini
