Installation & Licensing
Pop-up window while opening a file
4 REPLIES 4
469 Views, 4 Replies
Hi, I am using LT 2014. I changed my laptop and managed to re-install the program. However, I found out that all files what I have saved after re-installation, gives annoying pop-up window while opening. Please see the capture attached.
Any ideas how to solve this out?
Thanks!
4 REPLIES 4
TravisNave
Check the box.  Then it will not verify the DWG origin anymore.
Autodesk Forums:
in reply to: TravisNave
Well thank you TravisNave, but the thing is I do not want that pop-up occur when my customers open the file. I assume that your answer does not have solution for that? Thanks guys!
pendean
You can't fix it for others except to try and re-save your files in LT2014 again (use RECOVER to fix them then SAVE).
dembkod
markus.makinen
Hello. Looks like the files were modified by some type of an external program. A 3rd party plugin maybe? Accepting the checkbox should stop this from appearing. You could test on another machine to see if this will appear on other machines.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
