I just installed my AutoCAD LT 2009 onto my work computer, and am having issues with setting up the printers. Everything is said to have been installed correctly, but when I try to access the Add-A-Plotter shortcut, I continue to get the same error message:
"addplwiz.exe-Unable To Locate Component: This application has failed to start because prntvpt.dll was not found.
Re-installing the application may fix the problem."
After one re-install, and one un-install/re-install, I am still getting the message. As of right now, I can't even convert the files into a pdf so that I can print them from another computer. I appreciate any and all help.
Try this solution :
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14487632&linkID=9240617
Best regards.
