style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<TravisNave> wrote in messageFirst
href="news:6058318@discussion.autodesk.com">news:6058318@discussion.autodesk.com...
of all, relax. You are fine, you simply have a misconfigured AutoCAD
installation. You aren't going to hurt your network install or create any such
disaster for your company.
Now that you have taken a deep breath, you
simply need to reconfigure your AutoCAD so that it is no longer a stand-alone
version, but a network version instead.
I have listed this method
several times on this discussion group. It involves modifying the registry. I
know that this sounds scary to you as a regular user without an IT guy around,
but the method is very simple.
First, open your registry by clicking
Start then Run. This may not be in your Vista Start bar by default so hold the
Windows key and the letter R. In the run box, type regedit and click
OK.
In the registry, locate and expand the following keys on the
left:
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R17.1\ACAD-6001:409\AdLM
Note
that your ACAD-6001:409 may be different if you don't have vanilla AutoCAD.
Simply open whatever version you have here, obviously.
Now in the right
panel, you will see a REG_DWORD named Type with a value of 2a (42) listed.
Modify this value so that it is now hexidecimal value 19. When you click OK,
the value will be 19 (25) listed instead.
Start AutoCAD and point it
to your license server. You are done.
Good
luck!
