Installation & Licensing
New Member
101051490
Message 1 of 8 (3,826 Views)
Please help, I cant open my 3ds max design 2012
3826 Views, 7 Replies
12-27-2011 07:46 AM
I download the student 3ds Max Design 2012
mine is vista and choose Autodesk 3ds Max Design 2012 32-bit - English
When I run it, it stop with loading plug-in: C:\ Program Files\Autodesk\3ds Max Design 2012\stdplugs\HSDS.dlm
After I choose Change Graphics Mode- English, it still the same
Can anybody help? thx a lot, very urgent :'(
Product Support
byron.morales
Message 2 of 8 (3,788 Views)
Re: Please help, I cant open my 3ds max design 2012
01-11-2012 04:48 PM in reply to: 101051490
Please test resetting the HSDS.dlm configuration file.
1. Close 3ds Max Design 2012.
2. Browse to the following local user application preferences directory-
Windows VISTA / Windows 7
C:\Users\YOUR_USER_NAME\AppData\Local\Autodesk\3ds​MaxDesign\2010 - 32bit\enu\plugcfg
3. Rename the HSDS.dlm configuration file in this direcrtory to HSDSdlm_old
4. Restart 3ds Max Design 2012, new user application preference file will be created on startup.
I hope that the above information is useful.
If renaming the HSDS.dlm to hsdsdlm_old does not help. You can also copy the hsds.dlm from another working machine and see if that works.
Byron Morales
Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
Byron Morales
New Member
siddhesh
Message 3 of 8 (3,659 Views)
Same Problem with 3ds Max 2012
03-31-2012 08:38 PM in reply to: byron.morales
I am having the same problem with 3ds Max 2012 64-bit. When starting it up, it hangs on HSDS.dlm... I went into local app data folder and into the plugcfg folder but theres no HSDS.dlm file there.
New Member
markstr2
Message 4 of 8 (3,642 Views)
04-05-2012 01:26 PM in reply to: 101051490
Ditto. Same problem. Not seeing the noted file in my plgcfg folder.
New Member
dasuazo
Message 5 of 8 (2,619 Views)
02-17-2013 01:08 PM in reply to: byron.morales
Thank u so much!
I was having the same problem and I renamed the HSDS file and it worked!
Thank you. Days of trying to find solutions finally came to an end.
People... if you are having the same problem... try this! :smileyhappy:
New Member
gentlestev
Message 6 of 8 (1,872 Views)
06-10-2013 05:07 AM in reply to: 101051490
Help me friends. I bought 3dsmax design 2012. When i start it. It loads all the plugins perfectly but keeps still at 'starting 3dsmax......' without bringing up the user interface and no error even when i left it for almost 10hours i wont come up. Hlp me plzzzzzzzzzzz. Here or email stevenonyeje@gmail.com
New Member
Salander02
Message 7 of 8 (1,140 Views)
10-15-2013 12:10 PM in reply to: gentlestev
I had the same problem as gentlestev and it was solved when I chose Change Graphics Mode>English>Open GL
Do give it a shot and lemme know if it works out!
New Member
zev.richards
Message 8 of 8 (751 Views)
01-15-2014 07:44 AM in reply to: 101051490
In case any one cannot find the HSDS.dlm file in appdata directory stated above, I found mine in C:\Program Files\Autodesk\3ds Max 2012\stdplugs and changed it to HSDS.dlm.off. Max then loaded up fine. I hope I won't need it later.
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
