I'm trying to create a deployment for Plant DS Premium 2015 (including all products), and the Autodesk deployent tool crashes at the end of the image creation (cf. picture 1).
Note : I identified that Revit Structure was the problem : when I create an image with just Revit, it crashes and when I deselect it, il goes to the end.
Note 2 : I don't have acces to Internet on the station where I create the image.
Note 3 : I have logs if you want (but they are big ...)
Have you already seen this problem ? Could this come from an error in the original setup ?
Thank you,
Regards
I also have this exact same issue.
Deployment creation completes suscessfully if Revit Structure is not selected.
Deployment creation of Revit Structure only fails.
Any help would be much appreciated.
Regards
I downloaded Revit Structure 2015 and created a deployment from that sucessfully.
I don't really want to have to run 2 different deployments, however if no other solution is presented, that is how I will proceed.
