HI,
This is Peter Fabian, I want to install AutoCad 2013, and for that I had uninstalled AutoCad 2012 from my computer. After uninstallation, when I installed AutoCad 2013 the program would not allow me to open it. Why? This is happening, Please suggest me what should I do???
Peter Fabian
Hello Peter Fabian,
under the hefty stress, that is perhaps owed to your installation problem, you where opening this thread in the
false section of this forum and this is called hardware! That means you are here:
Autodesk Discussion Groups > Getting Started with your Autodesk Product > Hardware
But realted to your problem it should better placed here:
Autodesk Discussion Groups > Getting Started with your Autodesk Product > Installation & Licensing
I personally think this is a way better to get the right help and that many peoples should recognise your question
and helps you out!!!!
Kindly regards
RaoulM
Hello Peter Fabian,
What is the error that you are getting?
Have you tried launching it as another user with local Admin rights?
