Installation & Licensing
*Support\, Autodesk
Message 11 of 11 (31 Views)
Re:
05-23-2001 01:10 AM in reply to: *Broeckmann, Frank
Frank,
As I stated earlier in this thread AutoCAD 2002 will incorporate a license
switcher to change between FLEXlm network licensing and the Standalone
License Manager. This requires the runtime system to be installed during the
Client deployment.
Simon Gillis
Analyst
DPG Product Support EMEA
Autodesk WW Support & Services
"Frank Broeckmann" wrote in message
news:B7C4C4E148BFFB45E98C9B19754C4C70@in.WebX.maYIadrTaRb...
> Hi Dick!
> Thanks for your interest in this problem, i have already tested registry
and
> file swapping and it didn't work (I use the german versions).
> I think, the c-dilla license manager is a problem.
> It is not so important for me that it's worth to test it some further
days,
> but it would be a nice feature (hope the license problem will be much
easier
> in Acad 2002).
> I have a network and a local license, but if it's violating the license
> agreement I will not install both versions on a single computer (would
this
> be a problem, Bud?).
> Frank
> "Dick" schrieb im Newsbeitrag
> news:57E9B4A37611A08228797A65EAC82578@in.WebX.maYIadrTaRb...
> > Alright Bud, suppose this guy is in France. According to Frank Hervet
> ("Re:
> > I need to 'convert' 150 local licenses of AutoCAD to the network license
> > system." 4/25/01 in this news group) all that would be needed is to
swap
> a
> > dll. In that scenario you could easily create two icons on the desktop
> that
> > could point to a bat file that swapped the dll, or pointed to different
> > profiles that did the same thing. I do not use the French version but
if
> > this is true my bet is that it is not "supported" by AutoDesk which is
> > distinctly different than not possible.
> > If I were determined to do this my approach might be to configure two
> > workstations identically using an image program such as Ghost. Then
> install
> > the stand alone version on one and a network on the other. There are
> > several ways to check the difference between the two.
> > 1. Copy the program registry from one to the next and see what happens.
> If
> > swapping the registry "converts" between network and standalone then you
> are
> > set, just find the keys that are different. A simple bat file or VBA
> > program could easily change the key quickly.
> > 2. If swapping the registry didn't work then it is probably a file
thing.
> > Compare the essential directories (support, root, etc...) for
differences
> in
> > files, like maybe size or modified date. If you find differences try
> > swapping those files and see what happens. In the French version I bet
> that
> > the ADESKSYS.DLL file is just slightly different between the two
versions.
> > That could be my approach but I have only thought about it for a few
> > minutes, there is probably a lot better way to go about it.
> > My bet is that if you had a good head on your shoulders, enough drive,
and
> a
> > day or two to goof off with the problem then you could come up with a
> hack.
> > Now weather this violates some license agreement or something is beyond
me
> > but it absolutely positively must be possible even if AutoDesk does not
> > support it. All you have to do is find the 1's and 0's that are
different
> > and swap em'.
> > Telling someone that something is not "possible" achieves nothing. I
> agree
> > that someone could really mess things up badly if they weren't careful
so
> > they should be warned but not necessarily discouraged.
> > Bud Schroeder [ Autodesk Inc.] wrote in
> message
> > news:2A3B651EC4AABAE8AD2AE74B7B839E99@in.WebX.maYIadrTaRb...
> > > Hello Dick,
> > > Not sure what your not getting here, so this will be my last message
to
> > you.
> > > No it is not possible!!!
> > > Take care.
> > > Bud
> > > "Dick" wrote in message
> > > news:53D533F67C1402A67343CEA023C5A477@in.WebX.maYIadrTaRb...
> > > > Again, I stress that "not supported" and "not possible" are two
> > distinctly
> > > > different conditions. Just because it is difficult doesn't
> necessarily
> > > mean
> > > > it's not worth doing.
> > > > Bud Schroeder wrote in message
> > > > news:8C30CF8E20ABB7F9FFC24F9EFE35ABAE@in.WebX.maYIadrTaRb...
> > > > > Hello Dick,
> > > > > Side by side is not supported! It's not just a matter of tweeking
> the
> > > > > registry to get it to work. There are lots of things to consider
> like
> > > > third
> > > > > party compatibility, other Autodesk applications that use the
Common
> > > > Shared
> > > > > Directory, and a few other things. Please don't encourage any one
> to
> > > try
> > > > > and do this, or you could end up with one heck of a mess on your
> > hands.
> > > > > Take care
> > > > > Bud Schroeder
> > > > > Test Development
> > > > > Autodesk Inc.
> > > > > news:6158B3C499E6B979722FB9B557EE39FB@in.WebX.maYIadrTaRb...
> > > > > > Excuse me if this sounds crass, but if you know for a fact that
it
> > > > cannot
> > > > > be
> > > > > > done and why it cannot be done then you should give some sort of
> > > > > explanition
> > > > > > as to why. Otherwise simply stating that it is impossible does
> > > nothing
> > > > > but
> > > > > > discourage someone frome trying. Perhaps achiving side by side
> > > > > > installations would be hard enough to keep most folks from
> > attempting
> > > it
> > > > > but
> > > > > > my bet is that some extensive registry manipulation is all that
> > really
> > > > > needs
> > > > > > to be done.
> > > > > > news:638D887AC81A3296D5AF41402DF043A5@in.WebX.maYIadrTaRb...
> > > > > > > Hi Frank,
> > > > > > > This is not possible except if your running say AutoCAD 2000i
> and
> > > > > AutoCAD
> > > > > > > MAP 2000i. or other vertical products. Then you can do this.
> > As
> > > > far
> > > > > as
> > > > > > > having say standalone AutoCAD 2000i and Client or Network
2000i,
> > > this
> > > > > can
> > > > > > > not be done.
> > > > > > > Take care.
> > > > > > > Bud Schroeder
> > > > > > > Test Development
> > > > > > > Autodesk Inc
> message
> > > > > > > news:90EBB726C572999CD0C9D441694ED142@in.WebX.maYIadrTaRb...
> > > > > > > > Thanks for your answer.
> > > > > > > > But .. isn't there a trick maybe by manipulation the
registry
> > or
> > > > > > writing
> > > > > > > a
> > > > > > > > batch file for exchanging some files of Acad?
> > > > > > > > "Simon Gillis (Autodesk Support)"
> > > schrieb
> > > > im
> > > > > > > > Newsbeitrag
> > > > > news:842FC625AB183D7759CFE612394373BB@in.WebX.maYIadrTaRb...
> > > > > > > > > This is not possible in AutoCAD 2000i. You need to deploy
> one
> > or
> > > > the
> > > > > > > > other.
> > > > > > > > > In AutoCAD 2002 you will have the ability to switch
between
> > the
> > > > two
> > > > > > > > > providing you have purchased both a network and a
standalone
> > > > > license.
> > > > > > > > > Simon Gillis
> > > > > > > > > Analyst
> > > message
news:A88D62D017AAAFB58214B6578CDBCC15@in.WebX.maYIadrTaRb...
> > > > > > > > > > I want to install a network licensed AND a local
licensed
> > > > version
> > > > > of
> > > > > > > > Acad
> > > > > > > > > > Map 2Ki on ONE workstation (NT4 SP5). Is this possible?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
