Installation & Licensing
Painfully slow Revit starup after license move.
4 REPLIES 4
MarkMoorhead
474 Views, 4 Replies
I attempted moving my Network licenses for ABDS Premium from a Windows 2003 server to a Windows 2008 R2 server over the weekend after obtaining a new license file and putting the latest version of the NLM on the new server.  First Revit didn't prompt for a new license location until after I disabled my anti-virus and firewall on the new server.  Then, when I tried again, it finally prompted me for the new location, but it took 3-4+ minutes real-time before prompting, and another 3-4+ minutes to find the new license server and open the program.  I thought it may be a one-time deal, so I closed Revit and tried re-opening.  It found the license, but I timed it, and it took 4+ minutes to open the program.  Took that long to open the program every time, even after a restart.  The second open on the computer I was testing took <30 seconds before moving the licenses.
Any idea what the slow-down could be.  The new server has much better hardware, and the same amount of software as the old server.
Thanks for any ideas.
4 REPLIES 4
DarrenP
in reply to: MarkMoorhead
its probably still looking for the old server
try adding this system variable: http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/How-to-specify-license-se...
DarrenP
MarkMoorhead
in reply to: DarrenP
I believe I did.  Odd that it shouldn't know where the new server is after it prompts me for the new location and I tell it.
Thanks for the input, I will verify.
Mark
TravisNave
True, but it likes to keep track of the old on in its LICPATH.LIC file and also in the registry.  Setting the ADSKFLEX_LICENSE_FILE variable goes a long way to resolving this issue.  Darren's link should help out a lot.
Autodesk Forums:
MarkMoorhead
in reply to: TravisNave
Thanks Guys,
I thought I tried it, but when I double checked, either I erased it after trying, or didn't try.  In any case, I added the system variable, and looks like it fixed my problem.  I did monkey with the firewall a little too, but I think it was your suggested fix that did the trick.
Thanks a lot!
Mark
Administrator Productivity
