BUENAS TARDES, SOY ESTUDIANTE Y ME ENCUENTRO DESCARGANDO AUTOCAD INVENTOR 2014 A UN EQUIPO CON SISTEMA OPERATIVO 64 BITS WINDOWS 8, EN MEDIO DE LA DESCARGA ME APARECE UN PROBLEMA CON EL PAQUETE DE IDIOMA, DICE QUE ES PROBLEMA DE LA RED Y NO ES ASI, CUANDO DESCARGO DE NUEVO APARECE QUE INVENTOR YA HA SIDO INSTALADO Y QUE FALTA UN PAQUETE ME DIRIJE A UN LINK DONDE APARECE PARA DESCARGAR PRO LUEGO APARECE QUE ESE PAQUETE NO ESTA EN ESA UBICACION, AGRADEZCO SU COLABORACION
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
