Hello
We use Product Design Suite 2014 (both Standard and Pro) for computers with 32 bits and 64 bits. So we have 4 differents sources : PRDSS 32/64 bits and PRDSP 32/64 bits.
I see in PRDS 64 bits source folder that we have a x64 and x86 folders.
So I would like to know if we can user PRDSS and PRDSP 64 bits sources in order to install on 32 bits and 64 bits
Thx in advance for your help
Solved by m_latz. Go to Solution.
Solved by DarrenP. Go to Solution.
no
you can't install 64 bit software on a 32 bit OS
this is nothing new
you need to download the 32 bit versions of the suites
DarrenP
What you can do is create deployments for the 32-Bit and 64-Bit OS and then use CombineDeploy from Autodesk to create one package to install for the user. More info here from Autodesk:
regards
Markus
