If the system date and time are not in synch with the other two PCs, this
can cause a problem. The exact cause can be determined by listing the exact
error message that you get when you start AutoCAD, including the error
number such as [18.1.54].
--Cy--
wrote in message news:5878301@discussion.autodesk.com...
Greetings!
Our company purchased AutoCAD 2004 (Stand-Alone, boxes) several years ago.
Now I've got a task to share one license between 3 PC using PLU.
While Export and Import works fine with two of my PCs, the third one always
says the license imported successfully, but the place for the license brief
info in the PLU window is grayed-out and when I restart PLU on that PC
(immediately after import), I can see that the status of the license is
"corrupted". There is also a note saying that I need to reactivate the
license in order to export it from this PC. However, this license is
unusable even on PC where it was 'successfully' imported - AutoCAD suggests
me to Authorize the Product or leave immediately.
The process failed when I tried to reactivate the license on that PC as PLU
advised.
With reactivation on the source PC, I was able to reproduce the problem
exporting the license from any of 2 PCs that haven't described problem to
the troubled one.
I've tried to do a clean reinstall of AutoCAD on it deleting all Autodesk
information on the disk and in the registry, but the problem still exists
I always use File transfer method.
The OS on all 3 PCs are WinXP SP2 and AutoCAD was installed on them from the
same source.
How can I determine the reason causing failures of the license installation
on the single PC while it works fine on the others?
