DarrenP
DarrenP
Chances are good this is the display adapter or the drivers for the display adapter. Might also be the memory or even another device.
Are there any Windows Event Logs?
Start by booting into Diagnostic Mode with the license service for the Autodesk product enabled. You will find instructions for this here. Also, try with any external storage devices removed.
If things run well while in Diagnostic Mode update the display drivers. Update the drivers for the pointing device as well.
You might even need to open the case and make sure adapter cards and memory are properly seated in their slots.
Also don't forget viruses and malware. Make sure to run a complete virus and malware scan.
On step 4 of the reboot procedure on the Technical Solution Right-click MSCONFIG and choose Run as administrator. Otherwise you might try as a different or new account.
Gupdate is the Google Update Service.
