we use the Autodesk Infrastructure Design Suite Ultimate 2013.
85810IDSU_F
Autodesk Infrastructure Design Suite Ultimate Package
85994IDSU_2013_0F
If the client open any Product from the license the debug log shows this
(adskflex) OUT: 85810IDSU_F user@host
(adskflex) OUT: 85994IDSU_2013_0F user@host
(Total of 20 licenses issued; Total of 2 licenses in use)
That doesn't seems normal.
Could i manage the with the options file?
Please help.
Greets
Andi
That is not abnormal. To find out who has the 2 licenses in use, do a Perform Status Enquiry and verify there.
Hello. This seems partially normal. 85810IDSU_F is the product code, and 85994IDSU_2013_0F is the year of product that has pulled this code. This does not equate to this:
Basically, there is not enough information here to know why you are pulling two seats.
How many products are open and what YEAR?
Different years will pull extra seats, because different years are different products. In this case, if you had a 2013 license file and opened Civil 3d 2013, you pull one license. If you then, on the same machine, open another 2013 product from the suite, you should not pull another license, just the one.
If you then open Civil 3d 2012, you will pull a second seat.
You would need a more complete listing of the enquiry, and you would want to look at the debug.log file to see what else may be checked out.
Options files prevent users from pulling specific licenses:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=7459915&linkID=9240617
Thank you for taking part in our community!
So here are the logs
Debug:
17:13:31 (adskflex) OUT: "85810IDSU_F" rols300@WKSSVROLS300
17:13:31 (adskflex) OUT: "85994IDSU_2013_0F" rols300@WKSSVROLS300
Enquiry:
Users of 85810IDSU_F: (Total of 20 licenses issued; Total of 2 licenses in use)
"85810IDSU_F" v1.000, vendor: adskflex
floating license
rols300 WKSSVROLS300 WKSSVROLS300 (v1.000) (srvhlsvlic001/27000 101), start Mon 9/9 17:13
Users of 85994IDSU_2013_0F: (Total of 20 licenses issued; Total of 2 licenses in use)
"85994IDSU_2013_0F" v1.000, vendor: adskflex
floating license
rols300 WKSSVROLS300 WKSSVROLS300 (v1.0) (srvhlsvlic001/27000 201), start Mon 9/9 17:13
Andi
Your status enquiry is still not showing the entire information. The enquriy will always show the PACKAGE being checked out, then also the INCREMENT being checked out. Your status accounts for only the one user.
Post the entire status enquiry, not just a snippet. It should better explain the situation.
Here the complete enquiry
-------- Status -------- Flexible License Manager status on Mon 9/9/2013 17:15 [Detecting lmgrd processes...] License server status: 27000@srvhlsvlic001 License file(s) on srvhlsvlic001: C:\Program Files\Autodesk Network License Manager\IDSU2013delicense.lic: srvhlsvlic001: license server UP (MASTER) v11.10 Vendor daemon status (on srvhlsvlic001): adskflex: UP v11.10 Feature usage info: Users of 85810IDSU_F: (Total of 20 licenses issued; Total of 2 licenses in use) "85810IDSU_F" v1.000, vendor: adskflex floating license rols300 WKSSVROLS300 WKSSVROLS300 (v1.0) (srvhlsvlic001/27000 201), start Mon 9/9 17:13 Users of 85994IDSU_2013_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85994IDSU_2013_0F" v1.000, vendor: adskflex floating license rols300 WKSSVROLS300 WKSSVROLS300 (v1.0) (srvhlsvlic001/27000 201), start Mon 9/9 17:13 Users of 85798IDSU_2012_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85798IDSU_2012_0F" v1.000, vendor: adskflex floating license Users of 85827UTLDESN_2012_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85827UTLDESN_2012_0F" v1.000, vendor: adskflex floating license Users of 85749REVITST_2012_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85749REVITST_2012_0F" v1.000, vendor: adskflex floating license Users of 85882INFMDR_2012_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85882INFMDR_2012_0F" v1.000, vendor: adskflex floating license Users of 85841ARDES_2012_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85841ARDES_2012_0F" v1.000, vendor: adskflex floating license Users of 85536ACD_2011_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85536ACD_2011_0F" v1.000, vendor: adskflex floating license Users of 85557MAP_2011_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85557MAP_2011_0F" v1.000, vendor: adskflex floating license Users of 85559TOPOBSCLNT_2011_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85559TOPOBSCLNT_2011_0F" v1.000, vendor: adskflex floating license Users of 85503MAXDES_2011_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85503MAXDES_2011_0F" v1.000, vendor: adskflex floating license Users of 85604CIV3D_2011_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85604CIV3D_2011_0F" v1.000, vendor: adskflex floating license Users of 85600NAVMAN_2011_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85600NAVMAN_2011_0F" v1.000, vendor: adskflex floating license Users of 85543REVITST_2011_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85543REVITST_2011_0F" v1.000, vendor: adskflex floating license Users of 85683ARDES_2011_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "85683ARDES_2011_0F" v1.000, vendor: adskflex floating license Users of 71200ACD_2010_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "71200ACD_2010_0F" v1.000, vendor: adskflex floating license Users of 72500MAP_2010_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "72500MAP_2010_0F" v1.000, vendor: adskflex floating license Users of 72800TOPOBSCLNT_2010_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "72800TOPOBSCLNT_2010_0F" v1.000, vendor: adskflex floating license Users of 70000MAXDES_2010_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "70000MAXDES_2010_0F" v1.000, vendor: adskflex floating license Users of 73700CIV3D_2010_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "73700CIV3D_2010_0F" v1.000, vendor: adskflex floating license Users of 71400NAVMAN_2010_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "71400NAVMAN_2010_0F" v1.000, vendor: adskflex floating license Users of 73900REVITST_2010_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "73900REVITST_2010_0F" v1.000, vendor: adskflex floating license Users of 72600ARDES_2010_0F: (Total of 20 licenses issued; Total of 2 licenses in use) "72600ARDES_2010_0F" v1.000, vendor: adskflex floating license
Interesting.
Are you running any kind of adskflex.opt options file? Have you tried simply stopping, the restarting the service from the stop/start/reread tab?
yesterday i updated our license file to 40 licenses but the problem still occours.
Yes, we use an options file. Here it is.
It reserves 21 licenses for our education room and the rest for borrowing if needed. Limited to 90 days.
GROUPCASEINSENSITIVE ON HOST_GROUP ROLS3 wkssvrols300 wkssvrols301 ... ... ... RESERVE 21 85810IDSU_F HOST_GROUP ROLS3 MAX_BORROW_HOURS 85810IDSU_F 2160 TIMEOUTALL 3600
Andi
Hello. You need to also look at the debug.log file to see what products are checking out. This should tell us exactly what programs you are opening. I would also remove the options file and stop and restart the services, just to keep the possibility of the file being the cause out of the loop.
