• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    MichaelGoodness
    Accepted Solution
    Online Registration No Longer Generates Package Licenses?
    126 Views, 3 Replies
    10-02-2012 02:35 PM
    In the past, I've been able to use https://register.autodesk.com/ to register my licenses and get 'Package' info as well as 'Increment'. That doesn't seem to be the case any more. Is there a new procedure for acquiring these? I'm moving ADLM to a new server and need it to authorize software from 2011-2013.
    Please use plain text.
    philip.s
    Re: Online Registration No Longer Generates Package Licenses?
    10-02-2012 05:12 PM in reply to: MichaelGoodness
    Hi Michael,
    The Register Once site should automatically pickup whether or not your license is linked to an active Subscription Contract and spit out the associated license file type accordingly (package or increment).
    Alternatively, you can contact our Registration and Activation group for assistance or send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your license and server information.
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    *Expert Elite*
    TravisNave
    10-03-2012 10:56 AM in reply to: MichaelGoodness
    Philip is right.  Your license probably expired on Subscription and now you can only get the latest version.  You might check your renewal to see if it fell thru the cracks.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    MichaelGoodness
    10-05-2012 02:33 PM in reply to: philip.s
    It appears that our subscription did, in fact, lapse. Thank you both for the help.
