Installation & Licensing
Offsets function nearly unusable?!
3 REPLIES 3
wl30ford
289 Views, 3 Replies
I have been having a problem when trying to use offset. If I select offset and try to specify a distance the program crashes and everything not saved is gone. Can't figure out what I'm doing wrong. As soon as I touch the keyboard it crashes.
3 REPLIES 3
dgorsman
in reply to: wl30ford
You don't mention which program, or which OS.  Both of those are necessary to coherently answer any questions.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
wl30ford
in reply to: dgorsman
Ihave autocad LT 2012. on a HP with windows 7
dgorsman
I recommend looking in the AutoCAD LT board: http://forums.autodesk.com/t5/AutoCAD-LT-General/bd-p/43
There's a number of existing posts about OFFSET which may answer your question.
Administrator Productivity
