Installation & Licensing
Not able to install Autocad 2010 on win 7 DirectX 11
6 REPLIES 6
dvsrkumar
11517 Views, 6 Replies
I'm installing Autocad 2010 on windows 7. I got a problem at the first step. It required to install DirectX 9.0 before Autocad 2010. But windows 7 included DirectX 11. Why this error happened ? How to fix this issue to continue the installation?
Thank in advance
Raghu.
6 REPLIES 6
TravisNave
in reply to: dvsrkumar
The failure is likely with another prerequiste.  You might attach your setup log located in your %temp% location.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dvsrkumar
in reply to: TravisNave
Please find the attache setup log file. It is trying to install DirectX 9.0 Runtime and failed. But i have Direct X 11. I am using windows 7 Home Premium 64 bit and i am trying to install 64 bit Auto CAD 2010.
Please help me.
Raghu.
TravisNave
The issue is not DirectX as it is ignored due to the existence of the later version.  There should be another installation log file in addition to this as well that steps thru the installation process.
Autodesk Forums:
randy510
Since I'm having the same issue with 2011 on a Win 7 machine, here is the log of my latest attempt:
2010/8/5:12:40:16    Randy    MAXTOR-500GB    Install    .NET Framework Runtime 3.5 SP1    Failed    Installation aborted, Result=1603
Granville4879
in reply to: randy510
Can I take it that this was never resolved?
I am looking at moving our design users to Win 7 but the install appears to be in a hard loop on the "Installing Components" screen at the first step "DirectX 9.0 Runtime".
Thank you,
Granville
simply copy the contents of the cd to the hard disk and then install ... from hard disk...
simple
satinder
pathanko punjab india...
Administrator Productivity
