I'm installing Autocad 2010 on windows 7. I got a problem at the first step. It required to install DirectX 9.0 before Autocad 2010. But windows 7 included DirectX 11. Why this error happened ? How to fix this issue to continue the installation?
Thank in advance
Raghu.
The failure is likely with another prerequiste. You might attach your setup log located in your %temp% location.
Please find the attache setup log file. It is trying to install DirectX 9.0 Runtime and failed. But i have Direct X 11. I am using windows 7 Home Premium 64 bit and i am trying to install 64 bit Auto CAD 2010.
Please help me.
Raghu.
The issue is not DirectX as it is ignored due to the existence of the later version. There should be another installation log file in addition to this as well that steps thru the installation process.
Since I'm having the same issue with 2011 on a Win 7 machine, here is the log of my latest attempt:
2010/8/5:12:40:16 Randy MAXTOR-500GB Install .NET Framework Runtime 3.5 SP1 Failed Installation aborted, Result=1603
Can I take it that this was never resolved?
I am looking at moving our design users to Win 7 but the install appears to be in a hard loop on the "Installing Components" screen at the first step "DirectX 9.0 Runtime".
simply copy the contents of the cd to the hard disk and then install ... from hard disk...
simple
satinder
pathanko punjab india...
