Installation & Licensing
Non-reduundant FlexLM Install Question
9 REPLIES 9
Message 1 of 10
paul.ashley
368 Views, 9 Replies
If you have the FlexLM running on only a single server, and the server goes down or the connection to it is lost, is there a grace period before AutoCAD will not run anymore?
9 REPLIES 9
Message 2 of 10
in reply to: paul.ashley
There are some minutes that the server can be down before existing users
need contact with the license server.
http://jtbworld.blogspot.com/2005/07/autocad-network-license-and-heartbeat.html
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2008
http://www.jtbworld.com/autocad2008.htm
"pashley" wrote in message news:5693266@discussion.autodesk.com...
Message 3 of 10
paul.ashley
Am I correct in assuming that this is still true for 2008?
Also, when a license is checked out, for what length of time can the license be used? Is the time allowed dontrollable in the FlexLM?
Message 4 of 10
pashley said the following On 8/17/2007 11:35 AM:
It's not disclosed and not adjustable.
R.K. McSwain
http://rkmcswain.blogspot.com
Message 5 of 10
Yes this should still be true for the 2008 products as far as I know.
If you mean a borrowed license it is 6 months.
http://jtbworld.blogspot.com/2005/03/autocad-2006-and-borrowing-licenses.html
Other than that a license can technically be checked out forever.
Therefore I have it very visible on the html reports JTB FlexReport can
produce if a user has used a license for a long time.
Jimmy Bergmark
Owner/Developer
AutoCAD 2008
"pashley" wrote in message news:5693272@discussion.autodesk.com...
Message 6 of 10
TravisNave
It takes mearly minutes to get your license server back up and running on any other networked machine.
Autodesk Forums:
Message 7 of 10
paul.ashley
Don't you have to know the mac address of the server to point to? If so, how is that determined?
Message 8 of 10
TravisNave
No, just the hostname. The MAC is only used for the license file creation/validation.
It is quick to regenerate a license file if necessary, or simply clone a MAC address. In any case, I can move a license manager in less than two minutes.
Autodesk Forums:
Message 9 of 10
Usually there is a timeout as pointed out. By
default this is about 15 minutes.
Best Regards,
Henrik
Goldman
size=2>
href="http://www.x-formation.com/license_statistics/index.html">Track your
flexlm licenses and red...
Message 10 of 10
Yes this is how it works out for majority of users. The days with long
downtime are fortunately gone by now.
Cheaper and better computer equiptment naturally also has a part of the
reason why.
Best Regards,
Henrik Goldman
Track your flexlm licenses and reduce your costs -
Our licensing and software security blog - http://blog.x-formation.com/
Protect your software with LM-X License Manager -
http://www.x-formation.com/lm-x_license_manager/index.html
Administrator Productivity
