Installation & Licensing
No Properties Window - AutoCAD Architecture 2012
5 REPLIES 5
gilbert
1123 Views, 5 Replies
I need some help, this has been a problem since our entire office has installed this software.
One of the many problems we are having with AutoCAD 2012 is that the properties window is not showing up.  I've done some searches online and was able to find a temporary fix: when I unload the application Apcom.arx it miraculously opens!?!
Please help me find a permanent fix for this major problem because althought the unloading of that application works, at times it will crash the system entirely and have to restart.  Is there an issue with installation?  I've tried both re-installation and complete uninstall and reinstall but the issue remains.
Gilbert
5 REPLIES 5
david.lau
in reply to: gilbert
Can you also post something in the ACA section as well?
http://forums.autodesk.com/t5/AutoCAD-Architecture/ct-p/56
David Lau
Shawn_Niles
Typically, the pop up windows such as the Properties palette are controlled by the .Net Framework component of Windows. The 2012 AutoCAD product line requires .Net Framework 4.0.
To correct this issue:
1) On the Start menu, click Settings > Control Panel.
2) In Control Panel, double-click Add / Remove Programs (Windows XP) or Programs and Features (Windows Vista/7).
3) Uninstall all versions of .NET Framework. You may need to uninstall the most recent versions first.
4) Reinstall only the version of .NET Framework required for your software version. Refer to the list below for AutoCAD requirements. For vertical products, consult the product installation literature for the required .NET Framework version.
AutoCAD 2012/AutoCAD LT 2012 requires .NET Framework 4.0
4.0:
http://www.microsoft.com/downloads/details.aspx?familyid=9CFB2D51-5FF4-4491-B0E5-B386F32C0992&displa...
Shawn Niles
TravisNave
in reply to: Shawn_Niles
I agree.  You might also consider the .NET Framework Cleanup Tool if you continue having problems with this.  It's best to do full installs of Framework rather than update installations.
More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
In addition, I've experienced properties windows not working after using registry cleaners or other products like Norton Systemworks.  Sometimes using these products breaks Autodesk software.
Autodesk Forums:
gilbert
Thanks for your reply - would you suggest the following:
  1. Uninstall AutoCAD 2012.
  2. Uninstall all versions of .Net Framework.
  3. Install .Net Framework 4.
  4. Install AutocAD 2012.
Or... does the uninstallation and re-installation of AutoCAD make a difference?
TravisNave
Yes, if you're going to reinstall .NET, you should also do the same to your AutoCAD.
If you have any problems, use the cleanup tools that I recommended.  Good Luck!
Autodesk Forums:
Administrator Productivity
