Installation & Licensing
New lic file Cannot return borrowed license
8 REPLIES 8
Message 1 of 9
Squeezer53
8371 Views, 8 Replies
Our License Server went belly up while I had our AcadM license out on "borrow"
IT replaced the server and we had to get a new lic file which they have installed.
The new server name is the same as the old one and uses the same port as before but has a different computer id.
This worked transparently as planned and other clients are getting the new license without any action on our part but....
I cannot return the borrowed license that was taken out under the old lic file. ERROR: [-124.595.0]
For the next 2 weeks we will have an extra license, but will this be a problem on my machine when the borrow period expires? Should I just let it run out?
8 REPLIES 8
Message 2 of 9
in reply to: Squeezer53
There is no problem.
All your users are running fine there product.
The only problem you can have is if you can't connect to your server after the borrow period because you are out of your office.
If you are not in that case, as you say, just let it run out.
Message 3 of 9
TravisNave
As usual, Franck is exactly right.  The reason you get the error is because your NLM has been recreated.  The server doesn't know that the license is borrowed, so when the client tries to return it, you get the error.  It will be corrected once the borrow time lapses.
Autodesk Forums:
Message 4 of 9
Squeezer53
It is as I thought so I'll just wait & see...
Thanks for the replies.
Message 5 of 9
I just wanted to post a follow on to this post for those who may run into this issue. Some times the expiration of your license may occur at a not so convient time so you can do the following to return the old license and get a new one.
1. With Autocad closed. Change the date of your computer to a date in the future beyond the date that the license is set to expire.
2. Open Autocad and borrow a new license for any amount of time and then go ahead and return the license.
3. Close Autocad and Change the date of your computer back to today's date.
4. Open Autocad and borrow a new license for the period that you need the new license.
I had a user that was going to be out of town during the time his license was set to expire and when he tried to return his license early he got the [-124.595.0] error. This procedure allowed him to get a new license.
Message 6 of 9
TravisNave
You can just remove the borrowed license from the registry and reborrow.
Autodesk Forums:
Message 7 of 9
DarrenP
in reply to: TravisNave
travis is correct
you can do method 2 on this kb article
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10305068&linkID=9240617
DarrenP
Message 8 of 9
jobermeyer1960
in reply to: DarrenP
Link seems to be broken.
Message 9 of 9
TravisNave
in reply to: jobermeyer1960
Here is the corrected link from Darren's post above.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1...
Thanks!
Autodesk Forums:
Administrator Productivity
