Installation & Licensing
New installation Autocad 2013 will not open on Mac OS X 10.8.5
6 REPLIES 6
Sabra_IT
323 Views, 6 Replies
I have downloaded Autocad 2013 from the link provided by tech support and it will not open. It will bounce on the dock then show the splash screen and shut down. I have paid for a license and it will not open and I am unable to use. Can anyone provide a solution or version that will open?
Tags (1)
6 REPLIES 6
jessica.t
in reply to: Sabra_IT
Hi @Sabra_IT,
Are you trying to download AutoCAD 2013 on parallels / Bootcamp on your Mac or are you trying to download AutoCAD for Mac 2013? You may want to try re-downloading your software from the Virtual Agent.
Please let me know how it goes and if you have any other questions. Thank you!
Jessica Thrasher
david.lau
in reply to: jessica.t
This is an important workflow if you used Time Machine to import AutoCAD.
http://upandready.typepad.com/up_and_ready/2013/02/reset-standalone-licensing-on-the-mac.html
You can use the uninstaller for AutoCAD but you will need to delete/backup some files starting at step 2.
David Lau
Sabra_IT
I have tried to download again from the virtual agent from the Mac software link and also the Autocad link and selecting Mac version. They appear to be identical files. I am getting the same result - the app attempts to start, shows the splash screen and then shuts down. There is no Virtual Machine or Time Machine installations tied to the installation
Sabra_IT
Additionally I have installed a trial version Autocad LT 2013 and it is working. I installed Auto 2014 but had the same result as 2013. Can anyone advise on a fix for non-LT versions that will not open on Mac OS X 10.8.5.
david.lau
Can you backup the delete the .data file and restart the program?
http://upandready.typepad.com/.a/6a0147e3c68bef970b0162fe69f665970d-pi
David Lau
Sabra_IT
in reply to: david.lau
Deleting the preference files has not solved the problem. I am installing this after a license transfer for an installation that was purchase previously. Since we have purchased the license we need it too work.
Administrator Productivity
