Installation & Licensing
*Darin
Message 1 of 1 (60 Views)
Network node Names
60 Views, 0 Replies
03-31-2000 02:26 PM
You are close Jason, and thanks,
but we only save our drawings to novell server by windows explorer and do
not perform a "Save As" feature to save drawings. I think the problem is
occuring when we open and plot files if im not mistaked.
an example of a file is as below:
100-1936-30013F384DB.ac$
the autal file that was printed was 100-1936-300.dwg.
so it added something that looks like a CRC validation, if im right.
i dont know.
any ideas?
"Jason Martin" wrote in message
news:eee273a.0@WebX.SaUCah8kaAW...
> Having read/write privleges only on the server could be the problem (if I
> understand your post correctly). Anytime autocad does a save it actually
> does something like the following
> Check for an existing drawing.bak file, if .bak file exists delete it,
then
> rename drawing.dwg to drawing.bak
> Delete drawing.dwg
> Save curreing drawing as drawing.dwg.
> The ac$ file comes in only as a temporary file (either autobackup inside
> autocad, or in the case that the previous operation cannot be completed).
I
> think that the ac1 is created when the ac$ file cannot be deleted.
> The basic rule that I've seen is that you need change rights to whatever
> folder/volume you are storing the autocad drawings on. I think that R13
is
> doing it's best to work around this, but if you upgrade to R14 or A2K you
> will probably have more problems with only having read/write privleges to
> the volume where your autocad files are stored.
> hth
> jason martin
> frankfurt-short-bruza
> Darin wrote in message ...
> >Hello,
> >We are currently running a Novell Server, V4.10, with AutoCAD R13 for
> >Windwos Releases c4a, on all
> >the NT (SP6) Workstations.
> >We currently have around 25,000 autocad drawings on the novell server.
> >Every morning I come into work I have to delete about 10,000 temp/error
> >files, which have an extension of ac$or *.acl.I have changed all the
> network
> >node names in autocad under the config parameters to the computer name
> >of each user, but to no avail. All the temp files still come up as *.ac$
> >and*.acl.
> >The server is write/read only, does not have modify.
> >I have file locking turned off in CAD.
> >Any ideas.
> >Please Help
> >Darin Cyns
> >Design Engineer
> >Sabritec
> >dcyns@sabritec.com
> >http://www.sabritec.com
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
