• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Thomas, Alex
    Network license problems
    110 Views, 3 Replies
    01-21-2001 09:25 AM
    i am thining of switching form stand-alone to network licensing. obviously i
    may encounter a few problems but in general is it a good move.
    does it work over a WAN?
    if my server goes down how long before my workstation will close down?
    thanx in advance
    alex
    Please use plain text.
    *martin, jason
    Re: Network license problems
    01-23-2001 01:09 AM in reply to: *Thomas, Alex
    I believe that the adlm is the only way to go for more than just a few cad users.
    One of the major difference between the adlm install and the "standard" or local install
    is that you won't use the cd to install the client workstations. You will create an
    "installation image" on a server (or workstation for that matter) that the clients use to
    install. There is some information in some of the installation guides that walks you
    through it. It's really pretty much follow the bouncing ball.
    Will adlm work across a wan? Yes, but the client must be have connectivity to the adlm
    server by hostname (assuming that you are using and windows adlm and not netware) and I'm
    pretty sure that the adlm server has to be able to contact the client by hostname (Jerry?,
    help?). The biggest problem in the wan environment is usually the installation of autocad.
    Since you can't install from the cd and wan links generally aren't very high bandwidth
    (unless you've got a lot of $) then installing from the "installation image" can be
    problematic. If possible I'd try to bring the remote client machine into the office for
    the installation of autocad, make sure it works and send it back to the remote location.
    How long it takes for the workstations to close down is variable. Let's just say usually
    not very long. I recommend that you get a PI class machine and install ntw 4.0, sp6a
    install the adlm and nothing else. Don't let anyone touch it. Don't do anything with it.
    Just let it sit and issue licenses for autocad. Ours has gone out once in the last year
    (unscheduled).
    let us know if you need any specific help.
    hth
    jason martin
    frankfurt-short-bruza
    "Alex Thomas" wrote in message
    news:5A00D304643B712D79911EEEDB412AF3@in.WebX.SaUCah8kaAW...
    > thanx in advance
    > alex
    *milana, jerry
    01-23-2001 05:39 AM in reply to: *Thomas, Alex
    As soon as AutoCAD becomes aware that your license server is not out there
    you will begin to get warnings starting at six, then four and two minutes.
    After the six minutes of warnings, AutoCAD will prompt you to save changes
    (Yes/No) if no changes had been made since the last save, AutoCAD will
    simply terminate after the six minutes.
    Keep in mind that several minutes may go by before AutoCAD becomes aware
    that the server is down, so you actually get more time than the three
    minutes.
    jerry milana,
    Autodesk Product Support
    i
    > thanx in advance
    > alex
    *Thomas, Alex
    Re:
    01-24-2001 08:38 AM in reply to: *Thomas, Alex
    thanks peoples
    :smileyhappy:
    "jerry milana" wrote in message
    news:F54D11ED3D0935E82F507E96987AE768@in.WebX.SaUCah8kaAW...
    > minutes.
    > jerry milana,
    obviously
    > i
    > > thanx in advance
    > > alex
