Installation & Licensing
*Stanford
Message 1 of 5 (205 Views)
Network license Error
205 Views, 4 Replies
04-22-2002 01:40 AM
This message appears several times before finally opening AutoCAD session
over the network.
"Error: Failed to navigate to the locations:
file://C:\Program%20Files\Autodesk%20License%20Manager\Docs\FlexUser\all.htm
I'd like to know what this is telling me... it doesn't seem to effect the
AutoCAD session it is just annoying.
*Support], Chris Dodge [Americas Product
Message 2 of 5 (205 Views)
Re: Network license Error
04-22-2002 07:22 AM in reply to: *Stanford
Check this solution out:
http://support.autodesk.com/getdoc.asp?id=TS65132
When the client deployment was first installed, that must have been the HTM
file selected for the default Bulletin Board HTML page in the Today window.
Chris
"Stanford" wrote in message
news:BAA80CBC4D0ABC074632F1077F219F3B@in.WebX.maYIadrTaRb...
> over the network.
> Thanks
*Stanford
Message 3 of 5 (205 Views)
Re:
04-22-2002 08:33 AM in reply to: *Stanford
On my network copies... the edit button doesn't show up... so these
directions are impossible to follow. Is there a way just to get rid of the
today window or at least the internet functioning part?
"Chris Dodge [Americas Product Support]"
wrote in message
news:6F7988B299EBE9E155043AB203689841@in.WebX.maYIadrTaRb...
HTM
window.
| Chris
session
| > over the network.
the
| > Thanks
*Hervet, franck
Message 4 of 5 (205 Views)
Re:
04-22-2002 05:36 PM in reply to: *Stanford
When you made your image on your server you specifie the file locally
to be use in the bulletin Board. It's normally a network path used. Ex :
\\servername\share\board\welcome.htm
Each client try to find locally the file all.htm.
1- Modify the file CMC.DAT on the server for next install.
2- On the PC where you have the problem, open regedit and search all.htm.
Replace with the correct value.
Best regards
Franck Hervet
Responsable Informatique
Aricad
ZA de l'observatoire
4 avenue des trois peuples
78180 Montigny le bretonneux
Tel : 0139441818
Fax : 0130575885
http://www.aricad.fr
"Stanford" a écrit dans le message news:
DCD0E58C58B46F33E249A9755344B4EA@in.WebX.maYIadrTaRb...
the
> Thanks
> wrote in message
> HTM
> window.
> | Chris
> session
> | > over the network.
> the
> | > Thanks
*Hervet, franck
Message 5 of 5 (205 Views)
Re:
04-22-2002 05:38 PM in reply to: *Stanford
You can see this document from Autodesk also :
http://support.autodesk.com/getdoc.asp?id=TS62140
Best regards
Franck Hervet
Aricad
Tel : 0139441818
Fax : 0130575885
the
> Thanks
> wrote in message
> HTM
> window.
> | Chris
> session
> | > over the network.
> the
> | > Thanks
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
