Installation & Licensing
395 Views, 4 Replies
Network license Error
This message appears several times before finally opening AutoCAD session
over the network.
"Error: Failed to navigate to the locations:
file://C:\Program%20Files\Autodesk%20License%20Manager\Docs\FlexUser\all.htm
I'd like to know what this is telling me... it doesn't seem to effect the
AutoCAD session it is just annoying.
4 REPLIES 4
Check this solution out:
http://support.autodesk.com/getdoc.asp?id=TS65132
When the client deployment was first installed, that must have been the HTM
file selected for the default Bulletin Board HTML page in the Today window.
Chris
"Stanford" wrote in message
news:BAA80CBC4D0ABC074632F1077F219F3B@in.WebX.maYIadrTaRb...
> over the network.
> Thanks
On my network copies... the edit button doesn't show up... so these
directions are impossible to follow. Is there a way just to get rid of the
today window or at least the internet functioning part?
"Chris Dodge [Americas Product Support]"
wrote in message
news:6F7988B299EBE9E155043AB203689841@in.WebX.maYIadrTaRb...
HTM
window.
| Chris
session
| > over the network.
the
| > Thanks
When you made your image on your server you specifie the file locally
to be use in the bulletin Board. It's normally a network path used. Ex :
\\servername\share\board\welcome.htm
Each client try to find locally the file all.htm.
1- Modify the file CMC.DAT on the server for next install.
2- On the PC where you have the problem, open regedit and search all.htm.
Replace with the correct value.
Best regards
Franck Hervet
Responsable Informatique
Aricad
ZA de l'observatoire
4 avenue des trois peuples
78180 Montigny le bretonneux
Tel : 0139441818
Fax : 0130575885
http://www.aricad.fr
"Stanford" a écrit dans le message news:
DCD0E58C58B46F33E249A9755344B4EA@in.WebX.maYIadrTaRb...
the
> Thanks
> wrote in message
> HTM
> window.
> | Chris
> session
> | > over the network.
> the
> | > Thanks
You can see this document from Autodesk also :
http://support.autodesk.com/getdoc.asp?id=TS62140
Best regards
Franck Hervet
Aricad
Tel : 0139441818
Fax : 0130575885
the
> Thanks
> wrote in message
> HTM
> window.
> | Chris
> session
> | > over the network.
> the
> | > Thanks
Administrator Productivity
