When you made your image on your server you specifie the file locally
file://C:\Program%20Files\Autodesk%20License%20Manager\Docs\FlexUser\all.htm
to be use in the bulletin Board. It's normally a network path used. Ex :
\\servername\share\board\welcome.htm
Each client try to find locally the file all.htm.
1- Modify the file CMC.DAT on the server for next install.
2- On the PC where you have the problem, open regedit and search all.htm.
Replace with the correct value.
Best regards
Franck Hervet
Responsable Informatique
Aricad
ZA de l'observatoire
4 avenue des trois peuples
78180 Montigny le bretonneux
Tel : 0139441818
Fax : 0130575885
http://www.aricad.fr
"Stanford" a écrit dans le message news:
DCD0E58C58B46F33E249A9755344B4EA@in.WebX.maYIadrTaRb...
> On my network copies... the edit button doesn't show up... so these
> directions are impossible to follow. Is there a way just to get rid of
the
> today window or at least the internet functioning part?
> Thanks
> "Chris Dodge [Americas Product Support]"
> wrote in message
> news:6F7988B299EBE9E155043AB203689841@in.WebX.maYIadrTaRb...
> | Check this solution out:
> | http://support.autodesk.com/getdoc.asp?id=TS65132
> | When the client deployment was first installed, that must have been the
> HTM
> | file selected for the default Bulletin Board HTML page in the Today
> window.
> | Chris
> | "Stanford" wrote in message
> | news:BAA80CBC4D0ABC074632F1077F219F3B@in.WebX.maYIadrTaRb...
> | > This message appears several times before finally opening AutoCAD
> session
> | > over the network.
> | > "Error: Failed to navigate to the locations:
> | > I'd like to know what this is telling me... it doesn't seem to effect
> the
> | > AutoCAD session it is just annoying.
> | > Thanks
