• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Contributor
    Network install of A2K with license mgr.
    67 Views, 1 Replies
    03-29-2000 04:53 PM
    I've been trying for a few days to install Autocad 2000 on several machines using the ADLM license manager. I have installed ADLM on a machine that is going to act as the license manager, but which is not a server. ADLM is running on that machine.
    The problem comes when I try to install A2K on the client machines. I called Autodesk to get my Authorization code for the server copy. It is this huge number (25 digits).
    First question: Do I have to get another authorization code for the client machines?
    When I try to install A2K on the client machine, I am assuming that I will be using the Client and Autodesk License Manager Installation. What I would like to do is to install from CD onto the client machine.
    Second question: Do I have to create the network setup or can I install from CD and use the license manager?
    I had our system administrator help me out for a while with this. He went with the install from network path and now we have a client.exe on our server that installs Autocad. However, it asks for a authorization code. The code I got for the server is way too big and doesn't work (see question 1).
    Third question: Is this right path to achieve my installation goals?
    We have also upgraded 4 copies of R14 to R2000 network versions. I noticed that the serial numbers of the network versions are slightly different from the standalone. The network numbers begin with 180- while the standalone begin with 110-. We used the 110- number for the A2k install of ADLM.
    Fourth question: Should I have used a different serial number? That was the number on the box.
    I realize that this is a fairly long post and I apologize if it doesn't make sense. I tried calling Autodesk for help and they told me to call my VAR. My VAR doesn't have time right now. I have to get this done before we can deploy some new computers.
    Thanks in advance.
    Phil Boudreau
    CAD Coordinator
    Harding Lawson Assoc.
    (415) 884-3306
    Please use plain text.
    *pboudreau
    Re: Network install of A2K with license mgr.
    03-29-2000 04:53 PM in reply to: pboudreau
    Thanks in advance.
    Phil Boudreau
    CAD Coordinator
    (415) 884-3306
